Using TCS3/FM10/RH9 on Windows XP.
I have a lot of ordered lists in my procedures. Some of the steps in the procedures have bullets that have substeps. For example:
1 Text
o Text
a. text
b. text
The next numbered step should be 2. However, there is something about the substeps (a. and b.) that seems to throw the numbering off. Instead of getting 2, I usually get 1 again or sometimes I will get a number further down in the procedure.
I'm linking FM books into my project and everything is numbered correctly in the FM book.
Here's the HTML:
<li type="1"><p class="Steps">Do one of the following: </p></li>
</ol>
<ul type="disc">
<li><p class="StepsBullet">If you want to execute the command across
all running instances of a Sensor role on all logical servers in the
environment, then select <span style="font-weight: bold;">Broadcast
Command</span><span style="font-weight: bold;"> > </span><span
style="font-weight: bold;">Get Option</span>.</p></li>
<li><p class="StepsBullet">If you want to execute the command on a
specific instance of a role on a logical server, then do the following
in the <span style="font-weight: bold;">Sensors</span> panel:</p></li>
</ul>
<ol start="1">
<li type="a"><p class="substep_alpha_a">Select the check box next to
the Sensor(s) on which you want to execute the command.</p></li>
<li type="a"><p class="substep_alpha" style="margin-bottom: 17.000pt;">Select
<span style="font-weight: bold;">Get Option</span> from the drop-down
list.</p></li>
<li type="1"><p class="Steps">Click <span style="font-weight: bold;">GO</span>.</p></li>
Any ideas? Thanks in advance.
"I selected Convert Autonumber to HTML List for both." - that may be your problem - try the "convert to text" setting and see if that makes any difference. If that creates other issues for you, then it's into the CSS for you to fix the multi-level list, I think. See Peter Grainge's site (grainge.org) for info on lists.
How are you telling RH to interpret the lists in the Conversion Settings? Try an experiment with that setting.
On the Conversion Settings dialog box, I have mapped Substep_alpha in FM to substep_alpha_a in Robohelp. Also mapped Substep_alpha in FM to substep_alpha in RH. I selected Convert Autonumber to HTML List for both.
Oh, you lovely man! It worked.
Except now the second line of the substep is wrapping all the way to the number instead of aligning with the first letter of the preceding line. Can I impose on you to give me the answer to that one?
That's a CSS tweak - I don't know enough CSS syntax to help you out much (I know just enough to be dangerous), but I know there have been posts on the forum & on the Tech Comm blog (http://blogs.adobe.com/techcomm/) about messing around with it for lists.
