Show 2 replies
1. Re: Why would CS5 key-config say I can't use a key (combo) when I can?
Trevor.Dennis Dec 31, 2011 1:42 PM (in response to Astara_)'Ctrl Shift B' is Auto Color. Watch your history palet as you try possibly available shortcuts, and see if they do anyting.
2. Re: Why would CS5 key-config say I can't use a key (combo) when I can?
twenty_one Jan 1, 2012 1:57 AM (in response to Astara_)I don't understand where that message would come from. I only get "already in use and will be removed from xxx if accepted", and then I accept and everything's fine.
Incidentally, I have <shift+ctrl+B> assigned to Convert to Smart Object (no idea what it was originally), so it's not as if that particular shortcut is locked in any way.
What you cannot do is use single-letter (tool) shortcuts for menu items, but that's not the case here.
