1. Re: Track Text Edits inserts a deletion in the first space when adding text
Anjaneai Srivastava Jan 2, 2012 1:22 PM (in response to farrelldoc)Hi Karen,
I notice one thing that there is a "red hyphen" between "the end" in the first sentence which means there was a Deletion of a Space done, with TTE enabled.
What I believe is happening, that deletions are getting accepted over here, in this specific FrameMaker document, hence you are missing a space between them.
I would like you to do a test on the same document, so that we may verify if this is something specific to the document or not?
1) Delete a compelete word/phrase from the same sentence, repeat the same procedure that removed the space and notice this time, is the word too getting ommited along with that space?
2) Disable the TTE insert two spaces between 'the' and 'before', the Enable the TTE and write the same way as you had earlier, but begin adding text like as follows--
I placed my cursor at the ONLY_NEW_WORD_INSERTED before where I started adding text.
I wish, I could illustrate these steps in a less confusing manner, But please try them and let me know if it clears few things for you?
Good Luck, Karen.
Anjaneai
2. Re: Track Text Edits inserts a deletion in the first space when adding text
Winfried Reng Jan 12, 2012 5:37 AM (in response to farrelldoc)Hi Karen,
The reason for the deletion is this. In Format | Document | Text Options you have Smart Spaces activated.
When you insert the cursor before a space and type another space FrameMaker deletes this space as only a single space is allowed.
But FrameMaker cannot insert a new space as there is already one there. Track Text Edit applies only conditions. The text is still there.
Try it without Smart Spaces. Then everything should be fine.
But if you want to keep Smart Spaces, then you must accept this behaviour and always start typing after a space.
Best regards
Winfried
3. Re: Track Text Edits inserts a deletion in the first space when adding text
farrelldoc Jan 12, 2012 5:45 AM (in response to Winfried Reng)Thank you Winfried! That has been really bothering me. I will try it without smart spaces and rely on spell check to remove the extra spaces.
Thanks again!
Karen
