0 Replies Latest reply: Jan 2, 2012 11:52 PM by joeln3 RSS
    Print a grey image with transparency creates a color image
    joeln3 Community Member
      Hello,
      I have a document which contains some images with transprency. While I convert the document to grey only the DeviceGrey colorspace is in the document.
      But if I print the document (eg. using the PDF printer) the result will be a pdf document with ICCBasedRGB or ICCBasedCMYK colorspace instead of my DeviceGrey colorspace. While I optimize the document (and also optimize the transparency) then everything is OK.
      This is a known behavior? Do you knwo a document (white paper) which explains this behavior?
      Thanks in advance,
      Joe
