2 Replies Latest reply: Jan 3, 2012 11:09 PM by AnubhavRohatgi RSS
    Cutting around a picture
    sccottie
      I know I might sound like a moron but for 6 days now I have been trying to figure out how I cut part of a picture out ......save it...and discard the rest
        • 1. Re: Cutting around a picture
          Kim Isola Adobe Employee
          Hi Sccottie,
          Try this and let us know if it works for you:
          -Tap an image on your Collage canvas to select it
          -Tap the Edit icon in the upper right corner
          This puts you into mask mode, where you can create and edit masks for your image. I find it easiest to use the paintbrush tool, and "paint in" the parts of the image I want to keep (these areas appear at full opacity in masking mode); use the eraser tool to "erase out" parts of the image you do not want to keep (these areas appear at partial opacity with a checkerboard pattern in masking mode). You can also use the scissor tool to draw polygonal-shaped masks.
          Here's a snippet of video that shows masking in action (I set this link to jump right to the masking part, though you may find the entire video helpful):
          Make a mask in Collage
          Let us know if this is helpful. Thanks for posting!
          • 2. Re: Cutting around a picture
            AnubhavRohatgi Adobe Employee
            You can also double tap on an image to mask it out or draw on top of it, etc.
            --Anubhav
