3 Replies Latest reply on Mar 29, 2012 2:20 PM by Jenn Andrews
    Reader Extensions ES WebApp
    BapediBoupi
      Hi all,
      I have a problem when I try to reader extend a form using Reader Extensions webapp (http://[host]:[port]/ReaderExtensions).
      I can upload the form, select the rights and then when I click "Apply", the progress / waiting bar "Download" keep running and nothing happens.
      Did anyone ever encoutered this issue ?
      Is there a solution ?
      Thomas
        • 1. Re: Reader Extensions ES WebApp
          SForrest96 Champion
          Does this problem occur with all forms and documents that you ry to Reader Extend?  Have you checked the server log file to see if any exceptions are being thrown?
          Regards
          Steve
          • 2. Re: Reader Extensions ES WebApp
            BapediBoupi Newcomer
            Hi Steve,
            First of all, thanks for your response
            This problem seems to occur with all pdf files that I try to upload (tested 5 of them so far). There is absolutely nothing in the server log ...
            I tested connecting to RE from my computer and directly from the server, both have the same problem.
            I'm using ReaderExtensions V8.0 by the way.
            Thomas
            • 3. Re: Reader Extensions ES WebApp
              Jenn Andrews
              Flash Player 10 broke the Reader Extensions sample application included with LiveCycle ES 8.0.1, and 8.2.1. When you use it, it will essentially hang. The workaround is to revert back to Flash Player 9 on those machines you use as LiveCycle clients.
              This problem has been fixed in LC 8.2.1 SP3 as well as in ES2.
