This is what has happened the last dozen attempts. Support advisor was no help. Running OSX Lion Appreciate any assistance.
Exit Code: 6
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 37 error(s), 65 warning(s)
WARNING: DS013: Payload {0175676F-8C92-49F2-9131-D0D6AD654B41} AdobeHelp 3.4.0.0 is already installed and the session payload {298CF0B0-8B47-46DF-B726-8E4BFAD5432E} AdobeHelp 0.0.0.0 has no upgrade/conflict relationship with it.
WARNING: DS013: Payload {54D89F03-8EED-4FF9-BCDF-3B2E11D448A6} AdobeColorCommonSetCMYK 3.1.0.0 is already installed and the session payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK 3.0.0.0 has no upgrade/conflict relationship with it.
WARNING: DS013: Payload {45063C56-A2A2-4FD1-A56A-A964723EEE1E} AdobeColorCommonSetRGB 3.1.0.0 is already installed and the session payload {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB 3.0.0.0 has no upgrade/conflict relationship with it.
WARNING: DS013: Payload {AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule 3.1.0.0 is already installed and the session payload {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule 3.0.0.0 has no upgrade/conflict relationship with it.
WARNING: DS013: Payload {1A1E5FF9-D0FD-42A3-8E18-E5E7E95E1AB4} DynamiclinkSupport 5.5.0.0 is already installed and the session payload {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport 5.0.0.0 has no upgrade/conflict relationship with it.
WARNING: DS013: Payload {9FBC5BF9-5019-49D6-A1B3-6BB0E2A1FA54} Pixel Bender Toolkit 2.6.0.0 is already installed and the session payload {F8918124-1CFB-4AB9-9BC2-39B961DBBBEE} Pixel Bender Toolkit 2.0.0.0 has no upgrade/conflict relationship with it.
ERROR: DS013: Verifying payload integrity : Failed with code 1
WARNING: DW016: NOTE: Cannot set action to the payload {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5 2.0.0.0 as it is already upgraded by the payload {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0
WARNING: DW016: NOTE: Cannot set action to the payload {C7BDD22E-AD27-4B06-BEB9-F97BC4D89671} Flash Player 10.1.52.15 as it is already upgraded by the payload {DEA79551-23E3-430A-9B15-B544479B7DB2} Flash Player 10.2.153.1
WARNING: DW016: NOTE: Cannot set action to the payload {1EC2407F-6A7B-4A3C-9F46-C812EE3D44FD} HIL Help Search 1.0.0.0 as it is already upgraded by the payload {270C312D-7EC7-474C-BEB2-79CD398E02A3} HIL Help Search 1.0.0.0
----------- Payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 9.9.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/Application Support/Adobe/PDFL/9.9/Fonts/AdobeFanHeitiStd-Bold.otf" Error 0(Seq 50)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 50)
----------- Payload: {298CF0B0-8B47-46DF-B726-8E4BFAD5432E} AdobeHelp 0.0.0.0 -----------
WARNING: DW036: Payload cannot be installed due to dependent operation failure
----------- Payload: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content 10.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/Application Support/Synthetic Aperture Adobe CS5 Bundle/Color Finesse 3 Plug-in User's Guide.pdf" Error 0(Seq 1)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 1)
----------- Payload: {D348C659-234A-497E-9E75-92D1AB019C8C} Creative Suite 5 Master Collection 5.0.0.0 -----------
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5: Install failed
ERROR: DW050: - SiteCatalyst NetAverages: Install failed
ERROR: DW050: - Adobe AIR: Install failed
ERROR: DW050: - AdobeColorCommonSetCMYK: Install failed
ERROR: DW050: - Adobe Mini Bridge CS5: Install failed
ERROR: DW050: - Adobe Media Player: Install failed
ERROR: DW050: - Adobe SING CS5: Install failed
ERROR: DW050: - AdobeColorJA CS5: Install failed
ERROR: DW050: - Adobe BrowserLab CS Live: Install failed
ERROR: DW050: - CSXS Story Extension: Install failed
ERROR: DW050: - Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US: Install failed
ERROR: DW050: - Adobe Illustrator CS5: Failed due to Language Pack installation failure
ERROR: DW050: - AdobeColorEU CS5: Install failed
ERROR: DW050: - AdobeColorCommonSetRGB: Install failed
ERROR: DW050: - Adobe CSXS Extensions CS5: Install failed
ERROR: DW050: - Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US: Install failed
ERROR: DW050: - Adobe Toolhints CS5: Install failed
ERROR: DW050: - Adobe InDesign CS5 Application Feature Set Files: Install failed
ERROR: DW050: - Adobe InDesign CS5 Application Base Files2: Install failed
ERROR: DW050: - Adobe InDesign CS5 Application Base Files: Failed due to Language Pack installation failure
ERROR: DW050: - PDF Settings CS5: Install failed
ERROR: DW050: - Adobe Linguistics CS5: Install failed
ERROR: DW050: - Adobe InDesign CS5 Common Base Files: Install failed
ERROR: DW050: - Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack: Install failed
ERROR: DW050: - AdobePDFL CS5: Install failed
ERROR: DW050: - Adobe After Effects CS5 Third Party Content: Install failed
ERROR: DW050: - Required Common Fonts Installation: Install failed
ERROR: DW050: - AdobeColorNA CS5: Install failed
ERROR: DW050: - Adobe Buzzword CS5: Install failed
ERROR: DW050: - Recommended Common Fonts Installation: Install failed
ERROR: DW050: - Adobe ReviewPanel CS5: Install failed
Have you tried the troubleshooting steps in this knowledgebase article? http://kb2.adobe.com/cps/843/cpsid_84332.html
Yes I have. Issue remains
Bluecrew84 the Adobe Support Advisor includes an option to package for support. Can you please select that option and respond back to this thread with your token number. Alternately you can review the installation log yourself by reviewing Troubleshoot CS5 and CS5.5 installation with install logs.
Well the advisor tool has crapped out as well. Here is screenshot. Really puzzled about this. All seemed well a few days ago and it just seems to be effecting illustrator and indesign
It could end up being related actually. Both the Adobe Support Advisor and portions of the Creative Suite utilize Adobe Air. I would recommend troubleshooting your installation of Adobe AIR utilizing document Troubleshoot AIR installation | Mac OS.
Without the Adobe Support Advisor you will either need to contact our support team to assist with reviewing your installation logs or proceed through Troubleshoot CS5 and CS5.5 installation with install logs. The document contains the same process which I would go through if I was able to obtain your token number. All of the error messaging is publically searchable as well at Adobe.com.
I uninstalled everything, restarted then did a fresh install. All seems well as of now. Thanks for your help.
