Hello,
I have thre questions, but they are related.
For some things, I have found example code.
I have found examples showing how to open all the files in a book.
var openedBook = app.ActiveBook
function openBookFiles(openedBook)
var bookChapter=openedBook.FirstComponentInBook
var chapterId = bookChapter.id
while(chapterId)
var chapterName = bookChapter.Name
chapterId = openFile(chapterName)
bookChapter = bookChapter.NextComponentInBook
chapterId = bookChapter.id;
That part works fine.
I found an example for saving the whole book to PDF:
function savePdf(openedBook,pdfName)
var params = GetSaveDefaultParams()
var returnParamsp =new PropVals()
var ft = GetPropIndex(params, Constants.FS_FileType)
params[ft].propVal.ival =Constants.FV_SaveFmtPdf
openedBook.Save(pdfName, params, returnParamsp);
return
That works fine too.
I tried to modify the above to save to a single HTML file.
function saveHTM(openedBook,htmName)
params[ft].propVal.ival =Constants.FV_SaveFmtFilter
var fth= GetPropIndex(params, Constants.FS_SaveFileTypeHint )
params[fth].propVal.ival ="0001ADBEHTML"
openedBook.Save(htmName, params, returnParamsp)
return
The above does not work at all.
I would like to make the above work.
I would also like to save per-chapter PDFs and per-chapter HTML files.
However, I have not been able to figure out how to save per-chapter anything.
Hello,
I figured out how to get a per-chapter object to save and print to PDF files.
I needed to use app.ActiveDoc after I opened a file.
while(chapterId)
openedChapter= app.ActiveDoc
params[ft ].propVal.ival =Constants.FV_SaveFmtPdf
openedChapter.Save(openedChapter.Name + ".pdf", params, returnParamsp);
Are there problems with this?
I still cannot save to HTML.
