Learn about Edge Delivery Services in upcoming GEM session
SOLVED
How do you populate 1 text box with multiple dropdown values
Avatar
Former Community Member
I can populate a text box with a value from a dropdown, however if I have 2 dropdown values going to the same text box (multi-line), the second dropdown value removes the first value.
(Similar code on Dropdown 1 and Dropdown 2)
Change Event - JavaScript
if(xfa.event.newText == 'No'){
form1.page1.subform2.description.rawValue="No location listed";
if(xfa.event.newText == "Partial location"){
form1.page1.subform2.description.rawValue="Partial location listed";
Do I have to Concat the fields in the 1 text field to get it to list multiple dropdown values, and if so how do I do that?
Thanks in advance for your help.
1 Accepted Solution
Avatar
Correct answer by
Solved:
Place this script in the subform root level in the FormReady event -JavaScript.
var oList = this.getDeltas ();
for (i=0; i < oList.length; i ++)
   var oDelta = oList.item(i);
   oDelta.restore ();
Answer was found at http://forms.stefcameron.com/2008/09/29/restoring-the-of-your-form/
Avatar
Is this what you are after?
// form1.page1.subform1.tf::calculate - (JavaScript, client)
if (form1.page1.subform1.color.selectedIndex != -1 && form1.page1.subform1.fruit.selectedIndex != -1) {
          this.rawValue = form1.page1.subform1.color.rawValue + "\n" + form1.page1.subform1.fruit.rawValue;
else {
          if (form1.page1.subform1.color.selectedIndex != -1 && form1.page1.subform1.fruit.selectedIndex == -1) {
    this.rawValue = form1.page1.subform1.color.rawValue;
          else {
    if (form1.page1.subform1.color.selectedIndex == -1 && form1.page1.subform1.fruit.selectedIndex != -1) {
      this.rawValue = form1.page1.subform1.fruit.rawValue;
Steve
Avatar
Thanks Steve for your help on this, you are amazing!
That is close.  I am actually trying to display specific values from the dropdown.
So for your example, lets say I want just Red and Green values from the color field and Apples and Pears from the Fruit field to populate the textbox.  I also want to change the drop down value of "Red" to say "Ruby Red" to in the Text box.  Is that possible?
Avatar
YAY - I got it figured out!
On Color Drop Down - Change Event, JavaScript
if (xfa.event.newText == 'Red') {
     form1.page1.subform1.textbox.rawValue="Ruby Red";
if (xfa.event.newText == 'Green'){
     form1.page1.subform1.textbox.rawValue="Light Green";
On Fruit Drop Down - Change Event, JavaScript
if (xfa.event.newText == 'Apple') {
     form1.page1.subform1.textbox.rawValue="Granny Smith";
if (xfa.event.newText == 'Pear'){
     form1.page1.subform1.textbox.rawValue="Bartlett";
On Text Box - Calculate Event, JavaScript
Thank you Steve for pointing me into the right direction.
Avatar
It works for only a few drop down values, if I get more than 6 going it displays only the last drop-down value.  What am I doing wrong?
Avatar
Changed the event from Change to Calculated and then the value type "Calculated - Read only" to "Calculated - User can override" and it didn't work.  Text box is blank.
Avatar
HUMMMMM – How would I add the dropdown fields to the text box?
Eve Tracy
Avatar
You need to remove the script from each drop-down change event and put all the script on the description calculate event. For example,
// form1.NonCompliancePage.subform2.description::calculate - (JavaScript, client)
var str = "";
if (form1.recordKeepingPage.RecordKeeping.rk_BusName.rawValue == "Required Records - No business name listed" || form1.recordKeepingPage.RecordKeeping.rk_BusName.rawValue == "Required Records - Partial business name listed") {
          if (form1.recordKeepingPage.RecordKeeping.rk_BusName.rawValue == "Required Records - No business name listed") {
                    str = "Required Records-No business name listed" + "\n";
          else {
                    str = "Required Records - Partial business name listed" + "\n";
if (form1.recordKeepingPage.RecordKeeping.rk_StAddress.rawValue == "No" || form1.recordKeepingPage.RecordKeeping.rk_StAddress.rawValue == "Partial address" || form1.recordKeepingPage.RecordKeeping.rk_StAddress.rawValue == "P.O Box only") {
          if (form1.recordKeepingPage.RecordKeeping.rk_StAddress.rawValue == "No") {
                    str =  str + "Required Records-No address of the application listed" + "\n";
          else {
                    if (form1.recordKeepingPage.RecordKeeping.rk_StAddress.rawValue == "Partial address") {
                              str = str + "Required Records-Partial address listed" + "\n";
                    else {
                              str = str + "Required Records-PO Box only listed" + "\n";
this.rawValue = str;
Steve
Avatar
Thank you so much!  This is exactly what I was wanting to do, you are Amazing!
Avatar
I have another question regarding the script to populate a text box with multiple dropdown values.
How do you save the form state (keep the page visible after it has been saved)?  This form will be connected to a signature pad, so it has to be certified and preserve scripting changes to form when saved is set to manually.
I can save the form state of several other hidden pages using this code in the initialize event:
if
(this.rawValue==1)
{subformName.presence="visible";}
else
{subformName.presence="hidden";}
However, since I have multiple fields writing to a text box using the calculated event, I can't seem to save the form state using the code above.
Please help, I have been searching forums and can not find a solution to this one.
Avatar
Correct answer by
Solved:
   oDelta.restore ();
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
