RH9 Is there a "no cache" switch?
Participant ,
Jan 11, 2012 Jan 11, 2012
We're having problems immediately seeing some topics live because of cache issues on the proxy server. My programmer asked me to poke around in the project to see if there was a switch in the primary layout that would make "no cache" the default for all of the topics, but we couldn't find it.
He does NOT want me to copy/paste "no cache" HTML code into the individual topics because he said the code may go away with future updates.
Is there some setting I can use to do this?
1.6K
Hi there
Sorry, but there is no setting I'm aware of for this.
Please feel free to suggest it! (Use the Wish Form link in my sig)
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
There's no option that I know of. A solution may be: You can use a search and replace operation on your output to quickly replace all occurances of <head> with <head><META HTTP-EQUIV="CACHE-CONTROL" CONTENT="NO-CACHE">. This will add the required HTML code in your output, but when you generate your output again you need to execute the search and replace operation again.
Greet,
Willam
Engaged ,
The best option available as of now is to use extendscript to make change in the output files. this way each time the output is generated, the script will patch all files, and at any point in time you can change the script as required.
Engaged ,
Jan 12, 2012 Jan 12, 2012
Just to add to my reply, I created an extendscript to add no cache meta data in the output files. I am attaching the file, so that any RoboHelp user who wants to use this script can download and use it,
  1. Download the attached script file from URL provided https://workspaces.acrobat.com/app.html#d=z5FcCv0r*s5kvU6IIXuXTw
  2. Open RoboHTML 9
  3. Go to View >Pods >Script Explorer
  4. This will open a script explorer pod, right click on the pod and select import option, and browse to the downloaded script file
  5. NoCacheMeta script file will now show in the script explorer.
  6. Open the project where you want to run this script, Right click on the NoCacheMeta Script file shown in the script explorer, and select Run menu option.
  7. It will run the script file, which will show a UI to select the SSL which will be generated, and after generation, it will automatically add the no cache meta information to the output files.
Hope this helps.
Praful Jain
Adobe RoboHelp Team
Message was edited by Peter Grainge to fix link.
Guest
Aug 27, 2013 Aug 27, 2013
The link doesnt work anymore - does anyone have a copy of this script as i could do with it
James
Try again. I have updated the link.
@petergrainge
Guest
got it - excellent - Many Thanks
James
RoboHelp Documentation
Download Adobe RoboHelp
