I get the following error when attempting to debug my AIR-IOS app on an IPad 2.
The weird thing is that the logfile mentioned does not exist.
Any ideas?
- Abey
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_UNCAUGHT_CXX_EXCEPTION (0xe06d7363) at pc=0x764db9bc, pid=5400, tid=9024
# JRE version: 6.0_29-b11
# Java VM: Java HotSpot(TM) Client VM (20.4-b02 mixed mode windows-x86 )
# Problematic frame:
# C [KERNELBASE.dll+0xb9bc]
# An error report file with more information is saved as:
# C:\Users\ABEY~1.LEX\AppData\Local\Temp\AOT1326388929076\hs_err_pid5400.log
I have the same error.
The wierd is that the log file doesn't exists.
Anyway I try everything... to reinstal my Flash Builder, reinstall all versions of java. I even try to make Xmx and Xms bigger size.. but nothing... still got the error.
If I create new project... then everything works fine... Export Release Build work very well,
but if I try to Export Release Build for my large project... then this error comes up.
I look at my code and no find any errors...
Build for android works as well, the error comes up when I try to build for iOS.
Please Adobe - give us help how to fix this.
Thank you
