SImple regex not working?
Sep 27, 2006 Sep 27, 2006
I have a simple regular expression that validates a middle name:
<cfset valid = REFind("^[A-Za-z' ]*$",FORM.middlename)>
I want the middle name to be optional, but when I try a blank entry in the form, the REFind returns 0. I though the star (*) would solve the problem but I can't seem to get it to work.
Any help would be greatly appreciated.
Advanced techniques
526
LEGEND , Sep 27, 2006 Sep 27, 2006
Java is a bit more clever than CF. See this example:
<cfset s = "">
<cfset sRegex = "^[A-Za-z']*$">
<cfset i = reFind(sRegex, s)>
<cfoutput>#i#</cfoutput><br />
<cfset b = s.matches(sRegex)>
<cfoutput>#b#</cfoutput><br />
Adam
Advocate ,
Read the quickdocs (especially the first comment).
http://livedocs.macromedia.com/coldfusion/6.1/htmldocs/functa63.htm#wp1111015
Basically, if you do an REFind("^$",FORM.middlename) it will return 0 whether or not the string is blank.
Theoretically, I've made the expression optional by adding the (*) for zero or many occurances of the character set [A-Za-z' ]. Have I got this wrong?
Right. REFind() returns the character position at which the match starts,
right? So which character position would the match start at in a
zero-length string?
The problem here is there's no way of distinguishing between "no match" and
"match at position zero".
Adam
<cfset s = "">
Adam
Thanks Adam. I'll just use the Java method. The more I learn about the CF regular expression methods, the more I hate them.
Thank you.
I think they're fine (and much better in CFMX than in older versions).
REFIND() does exactly what it claims it does, and indeed was giving you the
correct answer, remember ;-)
CF and Java obviously use the same regex processor, so they have the same
shortcomings as far as what regex "grammar" they understand. For example
Perl's regexes do a whole bunch of stuff that neither Java nor CF can do,
and I presume PHP is the same.
I guess there are probably third-party Java classes out there that cover
more options, having said that (I've never had need to investigate yet).
I'd probably approach your situation in two steps:
<cfif not len(x) or reFind(regex,s)>
It's clearer in intend, for one thing.
Adam
Documentation
