10 Replies Latest reply on Jan 12, 2012 12:44 PM by DonJohnston
    Combining data from iptc fields
    DonJohnston Level 1
      Hello group. Happy New Year.
      I'm looking for a script which would perform an action of copying data from the city, state/prov and country fields and adding that data to the description field. I still wish to retain the content in the description field. My stock agency is requesting this be done in order to create a more complete picture caption for web display.
      Hoping the list can help! Thanks
      Don
        • 1. Re: Combining data from iptc fields
          Paul Riggott Level 6
          Happy new year Don, hope you have a good one!
          Please try this...
          #target bridge
          if( BridgeTalk.appName == "bridge" ) {
          combineFields = MenuElement.create("command", "Details to Description", "at the end of Tools","cft2012");
          combineFields.onSelect = function () {
          if (ExternalObject.AdobeXMPScript == undefined) ExternalObject.AdobeXMPScript = new ExternalObject("lib:AdobeXMPScript");
          var sels = app.document.selections;
          for(var z in sels){
          var t = new Thumbnail(sels[z]);
          var md = t.synchronousMetadata
          var Desc = md.read("http://purl.org/dc/elements/1.1/",  "dc:description");
          var City = md.read("http://ns.adobe.com/photoshop/1.0/",  "City");
          var Country = md.read("http://ns.adobe.com/photoshop/1.0/",  "Country");
          var Region =  md.read("http://ns.adobe.com/photoshop/1.0/",  "State");
          var DescAll = Desc + "\r" +City + "\r" + Region +"\r" + Country;
          var myXmpFile = new XMPFile( t.spec.fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_UPDATE);
          var myXmp = myXmpFile.getXMP();
          myXmp.deleteProperty(XMPConst.NS_DC, "description");
          myXmp.setLocalizedText( XMPConst.NS_DC, "description", null, "x-default", DescAll );
          if (myXmpFile.canPutXMP(myXmp)) {
                  myXmpFile.putXMP(myXmp);
                   myXmpFile.closeFile(XMPConst.CLOSE_UPDATE_SAFELY);
          • 2. Re: Combining data from iptc fields
            DonJohnston Level 1
            Hi Paul
            Many thanks!
            Please bear with me regarding getting this script going. I copied your code and pasted it into ExtendScript Toolkit in Adobe utilities CS5. I gave it a name and saved it to my Bridge Scripts folder. When I restarted Bridge i was asked if I wished to enable this script, so things looked good so far.
            But when I tried it on a nef file which contained info in the relevant fields nothing happened, so I don't know whether there is a bug in the script or whether I missed doing something trying to apply it. I clicked on a file and then I clicked on the script which now appears in the Tools window, but the info in the Description field remained the same.
            What am I missing?
            Hope 2012 is off to a great start for you!
            Don
            • 3. Re: Combining data from iptc fields
              DonJohnston Level 1
              Hi Paul
              OK, I tried it on a tif file and it worked! Great stuff. Many thanks again.
              Don
              • 4. Re: Combining data from iptc fields
                Sorry about that Don, NEF files are a pain in the backside
                Hopefully this code will work for NEF file only!
                It update the xmp file so after it has run you would need to refreash the folder (or select a diffirent folder and go back)
                #target bridge
                combineFields2 = MenuElement.create("command", "NEF Details to Description", "at the end of Tools","cfta2012");
                combineFields2.onSelect = function () {
                for(var z in sels){
                var Name = decodeURI(sels[z].spec.name).replace(/\.[^\.]+$/, '');
                var file = File(sels[z].spec.path + "/" + Name +".xmp");
                if(file.exists){
                     file.open('r');
                     file.encoding = "UTF8";
                     file.lineFeed = "unix";
                     file.open("r", "TEXT", "????");
                     var xmpStr = file.read();
                     file.close();
                     }else{
                         var xmpStr='';
                     var xmp = new XMPMeta( xmpStr );
                var arrItem=[];
                var items = xmp.countArrayItems(XMPConst.NS_DC, "description");
                for(var i = 1;i <= items;i++){
                 arrItem.push(xmp.getArrayItem(XMPConst.NS_DC, "description", i));
                try{
                var Desc = arrItem.toString();
                var City = xmp.getProperty(XMPConst.NS_PHOTOSHOP, "City");
                var Country = xmp.getProperty(XMPConst.NS_PHOTOSHOP, "Country");
                var Region =  xmp.getProperty(XMPConst.NS_PHOTOSHOP,  "State");
                xmp.deleteProperty(XMPConst.NS_DC, "description");
                xmp.setLocalizedText( XMPConst.NS_DC, "description", null, "x-default", DescAll );
                file.open('w');
                     file.write( xmp.serialize() );
                     file.close();
                     }catch(e){alert(e+"-"+e.line);}
                • 5. Re: Combining data from iptc fields
                  DonJohnston Level 1
                  Hi Paul
                  In retrospect I think it will work best with the tif files. Sorry to make you do the extra work for the nefs. I'll install it anyway, and I might find it useful going forward.
                  With respect to the first script (for the tif files) would it be possible to modify it so that the extra data is not on separate lines, rather it is all continuous. I expect there won't be punctuation marks, although I could add commas at the end of each field entry, but with capitals starting each entry I think a reader will follow the data path. I'm guessing (haven't heard back from my agency yet) that they will prefer the data to be in one continuous line.
                  Please advise.
                  Don
                  • 6. Re: Combining data from iptc fields
                    It might be best to use commas to separate the different fields Don.
                    This version appends each field with a comma and space between them ...
                    #target bridge
                    for(var z in sels){
                    var DescAll = Desc + ", " +City + ", " + Region +", " + Country;
                    The line that you might want to alter is ..
                    If you don't want the commas you could remove them just leaving a space.
                    • 7. Re: Combining data from iptc fields
                      DonJohnston Level 1
                      Hi Paul
                      I'll test that out shortly. Thanks a ton. I'll try that line variation and report back soon.
                      Best
                      Don
                      • 8. Re: Combining data from iptc fields
                        DonJohnston Level 1
                        Yes, the commas work well. I think the script will be exactly what I need.
                        My best to you and your family.
                        btw Check out this on line article. The text and description has been embellished somewhat but I had not control over that. I was contacted by Caters News Agency about some of my polar bear pictures and this is the first result, picked up by the Mail On Line. I chided them about not including my name in the copyright and my contact said that was an oversight by the Mail. Anyway
                        http://www.dailymail.co.uk/news/article-2082632/You-left-paw-right-paw-Dancing-ice-Polar-b ear-way.html?ito=feeds-newsxml
                        Cheers
                        Don
                        • 9. Re: Combining data from iptc fields
                          Fantastic pictures Don, I would have loved to have been there with my camera!
                          All the very best.
                          Paul.
                          • 10. Re: Combining data from iptc fields
                            DonJohnston Level 1
                            Hi Paul
                            I just realized that the agency works with jpegs but I see your revised script also works with jpegs which I just tested, which is excellent.
                            Don
