8 Replies Latest reply on Jan 17, 2012 8:19 AM by jay fresno
    Converting AVI to FLV or F4V
    jay fresno Level 2
      Using Captivate 5.
      I have an AVI file that has video and audio.
      When I tried to insert it into my Captivate presentation, a message appeared that it needed to be converted using Adobe Media Encoder. I went ahead and let the encoder do the conversion. It worked fine, except that the audio has completely vanished. I have Audio turned on in Preferences.
      I hope that someone knows about conversions and can help with this problem.
        • 1. Re: Converting AVI to FLV or F4V
          Erik Lord Adobe Community Professional
          It's been a while - did you ever get this issue resolved?
          Erik
          • 2. Re: Converting AVI to FLV or F4V
            jay fresno Level 2
            Eric,
            The issue has not been resolved. Since no one has made any suggestions, perhaps it can't be accomplished.
            • 3. Re: Converting AVI to FLV or F4V
              TheFlasher_net Level 1
              Depending on the source of the AVI the sound can be encoded (with a codec such as AC3, Vorbis OGG, etc). Try to convert it to MPEG and then back to FLV.
              Oh and by the way, remember to generate an FLV that runs at 30fps if you are going to embed it into Captivate or the sound and video will be desynchronized!
              • 4. Re: Converting AVI to FLV or F4V
                jay fresno Level 2
                Hi TheFlasher,
                Thanks for your reply.The AVI was obtained by capturing video information that was being displayed on my computer monitor, using RiverPast screen recorder. RiverPast Screen Recorder captured both the audio and the video, but RiverPast only saves as AVI. The next step was that I opened the AVI in Photoshop, and saved it as FLV from Photoshop. This maintained the video, but lost the audio.
                Would you mind giving more detail about how I would implement your suggestion -- Like specific software I would need to do the conversions of the audio and video?
                • 5. Re: Converting AVI to FLV or F4V
                  Wait a minute, you used Photoshop to save it as an FLV? That might be the reason the conversion wasn't made properly.
                  • Open Adobe Media Encoder and press the button Add...
                  • Browse your computer for the AVI file and click Open
                  • Now click the Settings... button
                  • In Format, make sure FLV | F4V is selected
                  • Make sure Export Video and Export Audio are checked.
                  • Click on the Format tab and check FLV
                  • Click on the Video tab and make sure the Frame Rate is set to 30fps
                  • Click OK and then Start Queue
                  That should do the trick, can you try this and tell me if that worked?
                  • 6. Re: Converting AVI to FLV or F4V
                    jay fresno Level 2
                    TheFlasher,
                    It would be wonderful if the Adobe Media Encoder would work. When I tried it, got the following message, and I didn't see a Settings button:
                    • 7. Re: Converting AVI to FLV or F4V
                      Did you update your Media Encoder to the latest versiion?
                      I guess the wisest choice is to open a support ticket with Adobe, but you can still try to use a freeware program to try to do the convert. I'm not sure I can recommend any of those in this forum, so just type "avi to flv freeware" in google and you will have some pages where you can download third party programs that could potentially do the job.
                      Next time you can try to use Captivate's screen recording capabilities, you will save a lot of headaches!
                      • 8. Re: Converting AVI to FLV or F4V
                        jay fresno Level 2
                        I have the newest version of Media Encoder, version 5.0.1.0.
                        Good suggestion to use Captivate's screen recording capabilities, and I can still do that. However, although Captivate captures video on my monitor, it does not capture the audio for some reason. What do I need in order for Captivate to record sound from my monitor?
