Ho scaricato il file d'installazione (con un po' di fatica perché uso una connessione telefonia mobile UMTS), poi avvio il programma d'installazione, ma questo si collega nuovamente ad Internet ma non riesce a completare il download e s'interrompe con errore.
Ho provato http://kb2.adobe.com/it/cps/191/tn_19166.html , ma in sezione Download di Flash Player con il programma di installazione manuale ci sono collegamenti a pagine errate ("Not found")
Stesso problema anche con Adobe Reader.
Automatic english transation (with google translator):
I downloaded the installation file (with a little 'fatigue because I use a UMTS connection), then launch the installation program, but this again is connected to the Internet but can not complete the download and stops with error.
Http://kb2.adobe.com/it/cps/191/tn_19166.html I tried, but in the Download section of the Flash Player with the setup manual there are links to pages incorrect ("Not found")
Same problem with Adobe Reader.
Messaggio modificato da Air Swan
Download the full installer from http://forums.adobe.com/thread/909550
Download the Adobe Reader installer from http://get.adobe.com/reader/direct/
If you need more help, please specify your operating system & browser details.
Thank you very much.
Sorry, I've seen that disucssion with link to direct download.
(I was tired and in hurry, after I have spent a lot of time on Adobe's site,a page send me to 2 or more page and so on -some in Italian, some in English, and I'm not very good in English-, not finding where to contact support, when I have seen this forum I posted directly).
Someone can fix link in
http://kb2.adobe.com/it/cps/191/tn_19166.html and similar transation?
Thank you for the feedback.
Can you tell me which link(s) are not working?
As I said in the first message, it's in "Download di Flash Player con il programma di installazione manuale" section (translation, something like: Download of the Flash Player with the manual setup) , that is http://kb2.adobe.com/it/cps/191/tn_19166.html#main_ManualInstaller
The link in "Flash Player 10 Plugin (tutti gli altri browser per Windows, ad esempio Firefox o Google Chrome)" pointing to http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player.exe is not working (The requested URL /get/flashplayer/current/install_flash_player.exe was not found on this server.)
I've tried now and "Flash Player 10 ActiveX (Internet Explorer)" pointing to http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player_ax.exe is not working too (The requested URL /get/flashplayer/current/install_flash_player_ax.exe was not found on this server.)
Maybe also more.
Thank you for pointing this out. It seems that the Italian version of http://kb2.adobe.com/cps/191/tn_19166.html is totally outdated.
I will ask someone from Adobe to look into it.
