I just downloaded a trial copy and need to get up and testing asap to evaluate what I can do.
My goal is to provide an initial technical printed manual for some custom software, with a goal to having that becoming a "help" system, possibly integrated into the software. I can learn fast, but I dont know which partof RoboHelp to start with.
Hi there
You might consider starting at the link below:
Cheers... Rick
Hi there
Cheers... Rick
Perfect - exactly what I needed - I got a basic help file CHM up and running in 3 hours using some existing word documents I cut and pasted. I should be able to get a demo to my client by Monday and try and convince him to pay for complete documentation the can pay for buying Robohelp
Your docs get right to the point and show me which type of help files I need to use/generate
If you are wishing to integrate the Help with the application. The Context Sensitive Help should be helpful for that, http://help.adobe.com/en_US/robohelp/robohtml/WS5b3ccc516d4fbf351e63e3d11aff59c571-7fdf.html
You can generate Printed Documentation -- Check Peter Grainge's Website, explaining everything precisely,
http://www.grainge.org/pages/authoring/printing/rh9_printing.htm
Hope it you get a good start.!
Good Luck.
Anjaneai
The Context Sensitive Help- I can generate the IDs now - but I have an issue with the inteface in the programming language I'm using, but thats not a RoboHelp problem. Thanks for the link for printing
Whilst CHMs can be run from a server (with some registry hacking) and webhelp can be run locally, nowadays it is pretty much the case that webhelp is for server applications and CHMs or desktop AIR Help are for locally installed applications.
