1. Re: Problem installing CS3 on Lion
MichaelKazlow Jan 16, 2012 7:28 PM (in response to LisaLK)Did you install CS3 from original disks or did you migrate the applications. If the later, that is why you are having problems.
2. Re: Problem installing CS3 on Lion
gingerchaka Jan 23, 2012 6:26 AM (in response to MichaelKazlow)I can't even get my CDs to run. They show up in disk utility but won't install. brand new macbook pro running lion. i am attempting to install CS4. i tried CS3 as well but neither one will install. talk about problems......And yes, i am attempting to run from original Adobe disks.
3. Re: Problem installing CS3 on Lion
terry-jackson Jan 25, 2012 7:29 AM (in response to gingerchaka)Are the discs Power PC code only discs?
We ran into this with our OEM CS 3 discs;
they will not install on Lion becasue Lion
no longer uses Rosetta.
It's one of the main reasons we had to move to 5.5.
Easy way to tell...Run a Get Info command on the setup file
inside the Disc 1..if it reports "Application ( PowerPC) "
and not "Application ( Intel)" then you'll know....
4. Re: Problem installing CS3 on Lion
BobLevine Jan 25, 2012 7:32 AM (in response to terry-jackson)CS3 was universal.
Bob
5. Re: Problem installing CS3 on Lion
Marion Brown May 21, 2012 12:44 PM (in response to gingerchaka)I have the same problem on an imac running Lion. The disks mount, but I can't get the installer to run.Did you ever find a solution?
