Tutorial: LiteBrite effect
photodrawken Jan 16, 2012 11:43 PMA little while ago, someone asked about creating a LiteBrite effect with PSE and the reply was to use another program. Well, I've found a way to do it with PSE.
Here's the effect:
To do this in PSE, you'll need to install the KillWhite plugin (http://mikes3d.com/extra/scripting-plugins/killwhite/). Then, there are two stages to creating the effect:
- Create a saved pattern of transparent holes in a black background.
- Apply that pattern to an image and use layer effects.
Let's get started!
Creating the patterns
- Create a 40px by 40px image with a black background.
- In the Layers Palette, double-click the background layer to convert it to a regular layer.
- Set the Grid (Edit...Preferences... Guides & Grid) to Gridline every 20 pixels and 4 subdivisions.
- Show the Grid.
- Set your Foreground colour to white.
- Select the Brush tool, using a "Hard Round 19 pixels" brush, and change its diameter to 30 pixels.
- Using the grid lines, click the Brush tool in the exact center of the image.
- Use the KillWhite plug-in to remove the white areas to transparency:
- Use Edit...Define Pattern to save the image, naming it "Holes Grid 30 px".
- Repeat steps 1-9, using a 20px by 20px image and a 15px Brush size, naming it "Holes Grid 15 px".
- Use Edit...Preset Manager...Preset Type (Patterns) to save the set containing these patterns.
Creating the Effect
- Open or create a simple image using a black background.
- Colour the image as you wish; the fewer colours, the better.
- If your image has more than one layer, merge them:
- Create a new layer.
- With that new layer selected, use the Paint Bucket tool to fill it with one of your patterns:
- With the grid pattern layer still selected, use the Paint Bucket tool to fill in the partially coloured circles with the appropriate colour(s):
- Then repeat, using black to fill in the appropriate circles. (Don't worry about the faint remaining circular lines, we'll take care of that next.)
- Use "Flatten Image" to merge the layers.
- Use Filter...Adjustments...Posterize with a setting of "4" to clean up those faint lines:
You can stop there, or
For some more fun
- Use the Magic Wand to select the black area, invert the selection, and use Ctrl+J to copy the coloured circles onto their own layer.
- Add a layer style to the circles layer.
Simple Inner Bevel:
Low Inner Shadow:
Both the Inner Shadow and Bevel:
And on and on and on...
Enjoy!
Ken
