I created an air application with Flash builder with a SQL Lite database. When I delete a row from one table, the problem is that the deletion is not updated. Only when I close and open the application the deletion is effective. How can I instantly update the database so that the change becomes effective immediately?
Not sure if this will help you but I generally use Atomic Commit.
http://www.sqlite.org/atomiccommit.html
Good Luck to you.
Bob
Thanks. I am not sure that will solve my problem. As I said the Database information has been changed, but the old information still seems to be in cache. It is also strange, because when I add a row it updates ok.
Apart from that do you have a simple code example for the AC?
