I have dropdown list that contains 8 items. The values are obviously 1-8 and refer to subforms.
In code I have
if (this.rawValue ==(1) {
BaggerSub.presence="visible";
elseif
if (this.rawValue == "2"){
BaggerSub.presence = "visible";
ZipperSub.presence = "visible";
endif
The problem is if I select item 1 on the list nothing happens. If Iselect item 2, then the script for item 1 works. If I select item 3 thenthe script for item 2 works.
I have the scripts in change.
Any suggestions of where I went wrong.
Craig
Total Likes
Ok new information.
If i choose an item and then choose it again it will load properly.
Total Likes
I think you're using the change:Event for your script.
In this case, the rawValue is not available, as it is set as very last.
Use xfa.event.newText instead.
ok. That doesn't seem o work. But what i did do is move my script from a change event to exit and it works-
Thank you.
Craig
Total Likes
