2 Replies Latest reply: Jan 17, 2012 9:04 PM by PhoeniX_01 RSS
    Flash Access License Generator .... receive error
    PhoeniX_01 Community Member
      I have prepared a file with parameters flashaccesstools.properties:
      licensegen.sign.certfile=trial6.pfx
      licensegen.sign.certpass=password
      and I want to create a file of the license a command:
      ...Access Professional Package\Command Line Tools\libs>java -jar AdobeLicenseGenerator.jar -c flashaccesstools.properties -m  testauth.f4v.metadata -o  -root root-license
      At license generation I receive the message:
      Adobe(R) Flash Access License Generator
      version 3.1.0435
      Signing credentials: trial6.pfx
      License type: Root
      Destination file: ....Flash Access Professional Package\Command Line Tools\libs\root-license
      Unable to load credential: Unable to load credential from trial6.pfx -- possibly wrong password.
      FAILURE
      These certificate and the password are checked up and used on the server of licenses.
      what is my error?
        • 1. Re: Flash Access License Generator .... receive error
          ZheWang Community Member
          The password string used for license server is scrambled, and the password string used in flashaccesstools.properties is NOT scrambled.
          From your question context I guess you were using scrambled password in the properties file, can you please try the un-scrambled password and let us know the result?
          Thanks.
          • 2. Re: Flash Access License Generator .... receive error
            Thanks, but now,there was other error
            # PKCS12 file containing credentials for signing license (Flash Access Professional License Server Certificate)
            licensegen.sign.certpass=password (not encription)
            and run a command:
            version 3.1.0435
            License type: Root
            Destination file: .....\Command Line Tools\libs\root-license
            Flash Access Professional License server certificate required
            FAILURE
