I am completely new in forms and javascrpit so my question is very simple:
I created a drop-down list with names.
I want to press a button and sumbit the pdf doc to the mail of the coresponding name of the drop-down list.
My code
The code has no bugs, but after pressing the button, the pdf is being sended allways to george@company.gr. It behaves as if I declared a constant bb="george@company.gr"
It does not take into consideration the value from the drop-down menu
Could you please help me ?
Regards
Solved! Go to Solution.
Total Likes
There is a second bug in your script, I didn't recognize before.
should be
Total Likes
The operator to compare aa ist wrong.
To compare you have to use either "===" oder "!==".
Total Likes
I tried, but it continues to give me the first e-mail ("george@company.gr") even if a select from the dropdown menu the 2nd Value "Nikos"
My modified code:
(Tried also with the alternaite "===")
By the way, i'm using javascript and not Formcalc
Regards
Total Likes
should be
Total Likes
It worked !!
Vielen Dank für die Hilfe !
Total Likes
