Locked
Data Services wizard not creating service
Jan 12, 2012 Jan 12, 2012
I am having huge problems with the Data Services wizard.
I am using Flash Builder 4.6 on a Mac (10.7.2).
Over the last year I have been working on a couple of proof of concept projects and now want to start work on a production version starting from scratch in a new project.
The Data Services wizard has worked fine for me in the past, but now I am having serious problems.
The first problem is the Data/Services window does not update when I create a new service with the wizard. (I am connecting to the Zenfolio Web Service.) If have to close the project and open it before I see the new service in the Data/Services window.
While this problem is more an inconvenience, more seriously the wizard does not create either the "services" folder or the "valueObjects" folder as it did in the past.
Now if I right click on a method in the service and select "Create Service Call", it creates the Call Responder but not the call itself.
The relevant log entry starts with
!ENTRY com.adobe.flexbuilder.dcrad 4 1 2012-01-12 22:39:20.962
!MESSAGE Component type services.zfapi.Zfapi not found.
If I create a "services" folder and copy the zfapi package from one of my previous projects, all works fine.
This probably gives me a workaround - although I haven't tested this to any extent yet.
It is very strange and worrying behaviour though.
regards
Chris
735
Jan 16, 2012 Jan 16, 2012
No, it turns out I don't have a workaround. The service that I copied is for an older version of the Zenfolio API so I am unable to refresh/update it to the new version.
This is causing errors when I try to call methods of the service.
regards
Chris
Jan 17, 2012 Jan 17, 2012
I tried installing Flash Builder 4.6 on a clean install of OS 10.7 - that works fine.
I tried uninstalling Flash Builder on my development machine and re-installing. No change. It still doesn't work .
This is so frustrating but I will keep working on it.
Chris
Jan 19, 2012 Jan 19, 2012
OK, here are the log entries created when I try to create the service:
!ENTRY com.adobe.flexbuilder.dcrad 4 1 2012-01-19 22:16:33.970
!MESSAGE
!STACK 0
java.lang.reflect.InvocationTargetException
          at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:479)
          at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
          at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
          at com.adobe.flexbuilder.dcrad.core.internal.ServicesManager.addServices(ServicesManager.java:476)
          at com.adobe.flexbuilder.dcrad.views.ServiceExplorerView$1.handleEvent(ServiceExplorerView.java:536)
          at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
          at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4128)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
          at org.eclipse.swt.widgets.Widget.sendSelectionEvent(Widget.java:1530)
          at org.eclipse.swt.widgets.Link.textView_clickOnLink_atIndex(Link.java:117)
          at org.eclipse.swt.widgets.Display.windowProc(Display.java:5781)
          at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
          at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:220)
          at org.eclipse.swt.widgets.Widget.mouseDownSuper(Widget.java:1092)
          at org.eclipse.swt.widgets.Widget.mouseDown(Widget.java:1084)
          at org.eclipse.swt.widgets.Control.mouseDown(Control.java:2519)
          at org.eclipse.swt.widgets.Display.windowProc(Display.java:5471)
          at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:2092)
          at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:2252)
          at org.eclipse.swt.widgets.Display.windowProc(Display.java:5535)
          at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:4989)
          at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5138)
          at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
          at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication.java:128)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3610)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
          at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:108)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:597)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.NoClassDefFoundError: org/apache/log4j/Priority
          at freemarker.log.Log4JLoggerFactory.getLogger(Log4JLoggerFactory.java:65)
          at freemarker.log.Logger.getLogger(Logger.java:255)
          at freemarker.template.utility.SecurityUtilities.<clinit>(SecurityUtilities.java:67)
          at freemarker.ext.beans.BeansWrapper.<clinit>(BeansWrapper.java:147)
          at freemarker.template.ObjectWrapper.<clinit>(ObjectWrapper.java:69)
          at freemarker.core.Configurable.<init>(Configurable.java:132)
          at freemarker.template.Configuration.<init>(Configuration.java:109)
          at freemarker.template.Configuration.<clinit>(Configuration.java:96)
          at fiber.gen.freemarker.FreemarkerModelGenerator.buildFreemarkerConfiguration(FreemarkerModelGenerator.java:328)
          at fiber.gen.freemarker.FreemarkerModelGenerator.<init>(FreemarkerModelGenerator.java:85)
          at fiber.gen.freemarker.FreemarkerStructuredTypeGenerator.<init>(FreemarkerStructuredTypeGenerator.java:62)
          at fiber.gen.as.ASClassGenerator.<init>(ASClassGenerator.java:84)
          at fiber.gen.as.vo.SuperGenerator.<init>(SuperGenerator.java:53)
          at fiber.gen.as.vo.ASValueObjectGenerator$2.<init>(ASValueObjectGenerator.java:225)
          at fiber.gen.as.vo.ASValueObjectGenerator.getBaseClassGenerator(ASValueObjectGenerator.java:222)
          at fiber.gen.as.vo.ASValueObjectGenerator.getTemplateNames(ASValueObjectGenerator.java:392)
          at fiber.gen.as.ASGenerator.getTemplateNames(ASGenerator.java:465)
          at com.adobe.model.core.generators.wrapper.CodeGenerationUtils.getTemplateResources(Unknown Source)
          at com.adobe.model.core.generators.wrapper.CodeGenerationWrapper.getTemplateResourcesForGenerator(Unknown Source)
          at com.adobe.model.core.generators.wrapper.CodeGenerationWrapper.generateCodeForGenerator(Unknown Source)
          at com.adobe.model.core.generators.wrapper.CodeGenerationWrapper.internalGenerateAllCodeForModel(Unknown Source)
          at com.adobe.model.core.generators.wrapper.CodeGenerationWrapper$2.run(Unknown Source)
          at com.adobe.model.core.generators.wrapper.CodeGenerationWrapper.generateAllCodeForModel(Unknown Source)
          at com.adobe.flexbuilder.dcrad.core.generation.ASVOGenerator.generate(ASVOGenerator.java:78)
          at com.adobe.flexbuilder.dcrad.core.internal.ServicesManager.generateVO(ServicesManager.java:538)
          at com.adobe.flexbuilder.dcrad.core.internal.ServicesManager.add(ServicesManager.java:403)
          at com.adobe.flexbuilder.dcrad.core.internal.ServicesManager.access$11(ServicesManager.java:356)
          at com.adobe.flexbuilder.dcrad.core.internal.ServicesManager$1.run(ServicesManager.java:484)
          at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
          ... 48 more
Caused by: java.lang.ClassNotFoundException: org.apache.log4j.Priority
          at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
          at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
          at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
          at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
          at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
          ... 77 more
Root exception:
          ... 77 more
