AUSST - Update Server issue: IIS7 406 errors, and ERROR: Invalid webfeed
Jan 18, 2012 Jan 18, 2012
I spent today configuring and installing an instance of the AUSST2.0 software, following http://www.adobe.com/content/dam/Adobe/en/devnet/creativesuite/pdfs/Up dateServerSetupTool_TechNote....
Here's where I am:
Via Firefox/IE I get the following when browsing to the Updaterfeed.xml:
XML Parsing Error: syntax error
Line Number 1, Column 1:
0001
Which I expect is ok...  the server is sending the updaterfeed.xml. I can also download the updates directly through IE or Firefox.  The corresponding entry in the IIS log is:
/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml - 80 - <MY IP ADDRESS> Mozilla/5.0+(Windows+NT+6.1;+WOW64;+rv:9.0.1)+Gecko/20100101+Firefox/ 9.0.1 304 0 0 196
When I attempt to do an update via Photoshop, I receive:
"The update server is not responding.  The server might be offline temporarily, or the internet or firewall settings may be incorrect.  Please try again later.  Error Code: U41M1C213 "
This happens regardless of firewall status locally or on the server.  Other communication to the server is fine.
the aamu.log on level 10 says:
2012-01-17T20:01:52: Entering slurpURL: (http://<SERVER IP>/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml) bytesPushed
2012-01-17T20:01:52: main download loop - waiting for network availability
2012-01-17T20:01:52: have network connection
2012-01-17T20:01:52: connected to: = http://<SERVER IP>/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml
2012-01-17T20:01:52: received status code from server
2012-01-17T20:01:52: slurpURL: (http://<SERVER IP>/AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml) bytesPushed = 0
2012-01-17T20:01:52: CFU(Webfeed): dumping webfeed: C:\Users\<MY USERID>\AppData\Local\Adobe\AAMUpdater\1.0\Data\webfeed.xml
2012-01-17T20:01:52: CFU(Webfeed): ERROR: Invalid webfeed. Could not read webfeed sequence number.
2012-01-17T20:01:52: UCGetprogress : (B) Returning with value = 1
2012-01-17T20:01:52: UCGetprogress : Check for updates returning state for reffId  =
2012-01-17T20:01:52: UCGetprogress : Check for updates returning state     = 41
2012-01-17T20:01:52: UCGetprogress : Check for updates returning outError  = 213
2012-01-17T20:01:52: UCGetprogress : Check for updates returning percent   = 0
2012-01-17T20:01:52: UCGetprogress : Check for updates returning unique error code string   = U41M1C213
2012-01-17T20:01:52: UCGetprogress : (D) Returning with value = 1
2012-01-17T20:01:52: Stepped into << UCGetUserPreferences >> call.
2012-01-17T20:01:52: Returning from << UCGetUserPreferences >> call with return value -  = 1
The subsequent IIS Log entry for this is:
GET /AdobeUpdate/webfeed/oobe/aam20/win/updaterfeed.xml - 80 - <MY IP ADDRESS> AAM+Updater+1.0 406 0 0 19
I've added the <add name=”SSINC-xml” path=”*.xml” verb=”*” modules=”ServerSideIncludeModule” resourceType=”Unspecified”> to my web.config, per http://blogs.adobe.com/oobe/2010/09/enterprise-in-house-update-hosting -for-cs5.html
I continue to get the U41M1C213 error whilst updating.  I can get the updates when I remove the AdobeUpdater.Overrides from C:\ProgramData\Adobe\AAMUpdater\1.0 (Win7)
Help?
Acrobat
4.3K
Community Beginner , Mar 07, 2012 Mar 07, 2012
If you come here via google, you can try this for my solution.
http://forums.adobe.com/message/4252886#4252886
This was my fix for pretty much the exact error the op was having. No guarantees
Adobe Employee ,
This is an Acrobat forum. Repost on a CS-related forum and someone may know what you are talking about.
ben
I was directed here by another adobe employee.   http://forums.adobe.com/thread/950769
I'll try again....  here is the current thread.  http://forums.adobe.com/thread/951039
Mar 08, 2012 Mar 08, 2012
This did fix my AUSST installation.  thanks!
