1. Re: Leading 0s
Daniel Flavin Jan 19, 2012 1:56 PM (in response to Paul Chernoff)Look at the Section Numbering options in the Pages Panel for leading characters.
It is not as simple as formatting in Excel, it requires an extra section for single digit pages & two digit pages.
2. Re: Leading 0s
[Jongware] Jan 19, 2012 2:04 PM (in response to Paul Chernoff)That's an option in the page numbering dialog, for CS4 and newer. No section tricks needed.
3. Re: Leading 0s
Really? Where?
4. Re: Leading 0s
P Spier Jan 19, 2012 2:33 PM (in response to P Spier)nevermind. I found it. It's in the style dropdown. Never noticed that before. Sweet.
5. Re: Leading 0s
Daniel Flavin Jan 19, 2012 2:40 PM (in response to [Jongware])Clearly I don't use that feature
6. Re: Leading 0s
[Jongware] Jan 19, 2012 3:37 PM (in response to P Spier)With CS3 I used this trick once: insert the required number of zeros plus one, in place of the page number code. Paste a [Paper] rectangle over the left side, making sure it shows just the number of digits you want (hence the extra '0', so you can position it right). Finally, insert the Page Number code at the end of the string of zeros.
Worked a treat too, except the client then decided he didn't want the leading zeros anyway. Oh well.
7. Re: Leading 0s
sakana1214 Oct 6, 2014 7:57 AM (in response to P Spier)Please elaborate your findings in detail instead of just saying plainly, "oh I found it.."
Where is the "style dropdown menu" found? Please explain it step-by-step so that the others can follow.
8. Re: Leading 0s
sakana1214 Oct 6, 2014 8:00 AM (in response to [Jongware])Please elaborate your findings in detail.
Where is the "page numbering dialog" found? Please explain it step-by-step so that the others can follow.
9. Re: Leading 0s
Daniel Flavin Oct 7, 2014 11:20 AM (in response to sakana1214)From the Pages Panel
Use the Flyout (Triangle) or Right Click on a page thumbnail and choose Numbering & Section Options
In the Numbering & Section Options dialog the Style field (dropdown) menu allows leading 0's
