looping insert
Sep 28, 2006 Sep 28, 2006
What is wrong with this code and how can I fix it.
I have a form with a loop to display all the options.
Then the user makes thier selections (via checkboxes) I need the checked
boxes to insert in the database with the email address. I keep getting that
the form elements are not defined.
The list works fine, I dumped the variables and they all appear correctly,
but I am getting the looping insert wrong.
Thanks.
Insert:
<cfif IsDefined('Update')>
<cfloop index="i" from="1" to="#optionList.Recordcount#">
<cfquery name="optout" datasource="mailer">
INSERT INTO Optouttable (outoption)
VALUES ('#Form.email#', '#Form.optionlist#')
</cfquery>
</cfloop>
<cflocation url="success.cfm" addtoken="no">
</cfif>
Form:
<cfset i = 0>
<cfloop query="optionList">
<table width="100%" border="0">
<cfset i = i+1>
<tr>
<td width="19%"><div align="right">
<input name="list#i#" type="checkbox" id="list#i#"
value="#optionList.listName#">
</div></td>
<td width="81%">#optionList.listName#
<input type="hidden" id="email" name="email"
value="#URL.email#"></td>
</tr>
</table>
</cfloop>
Advanced techniques
1.2K
Participant ,
In HTML forms, if a checkbox is not selected, the form variable is not passed when the form is submitted. So, you will need to check for the form fields existence before tryiong to use it.
One way you can handle this is to name all checkboxes the same name. Then a comma delimited list for all items checked will be passed when the form is submitted. However, you would still check for the form fields existence, or do a <cfparam>, but you will only need to do it once, rather than once for each item.
Not 100% sure what you mean. Each check box has a unique name based on the
loop. Box 1 is List1, Box 2 is List2, etc. Since the form is looping and
list all the values from the optionList query, it should match with
RecordCount I am using with the insert loop, correct?
I added this to the loop insert to check to see if the box is there.
<cfif IsDefined("list#i#")>
<cfif evaluate("list#i#") NEQ "">
</cfquery>
</cfif>
</cfif>
</cfloop>
</cfif>
What confuses me the most is that the error I am getting (and this has
happened in past posts) is that #Form.email# is not defined when I go to
insert.
Inside of a hidden variable I have <input type="hidden" name="email"
value="#Url.Email#"> it displays fine in the actual displayed form, but not
when I click the submit button.
Any ideas on why it seems to disappear??
Put <cfdump var="#form#"> at the top of your action page. This will
show you all the form fields and their values being submitted.
I suspect the problem is the #form.optionlist#. I do not see that field
defined in the form.
I tried that and it gave me the form.email not defined. Although it IS
defined in the form inside the loop.
Thanks for the headsup on the option list. I am sure that would be next to
be a problem. #optionlist# is the value of the list#i#.
Ok. How can I enter the form.list#i# inside the values area of the insert
since it is also dynamic. Will CF freak if I have #form.list#i##?
<quote>I tried that and it gave me the form.email not defined. Although
it IS defined in the form inside the loop.</quote>
So what fields showed up in the form dump. You did dump the entire
form, not just the one field correct. <cfdump var="#form#"> not <cfdump
var="#form.email#">.
<quote>Ok. How can I enter the form.list#i# inside the values area of
the insert since it is also dynamic. Will CF freak if I have
#form.list#i##?</quote>
Yes it will freak out. We have had this discussion before. My
preferred method is #form["list" & i]#. But you are going to run into
the undefined problem here because if a user does not check an checkbox
input that field is not returned and thus will be undefined.
This thread is about a similar problem. Maybe you will see something helpful.
http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=1&catid=3&threadid=1198187&ente...
Now when I dump I am getting nothing.....I am sooo lost. Here is my form and
here is my insert. Please let me know what I am doing wrong.
My Form:
<form action="" method="get" name="showMeMy">
<cfoutput>
<cfset i = 0>
<cfset i == i>
<tr>
</div></td>
<input name="email" type="hidden" id="email"
value="#Url.email#" />#URL.email#</td>
</tr>
</table>
</cfloop>
<td><input name="Update" type="submit" id="Update" value="Update
Subscription List"></td>
</tr>
</table>
</cfoutput>
</form>
Here is my insert:
INSERT INTO Optouttable (email, optionlist)
VALUES ('#myemail#', '#form["list" & i]#')
</cfquery>
</cfif>
</cfif>
</cfloop>
</cfif>
Ok, I seemed to have solved the issue with the email by moving it outside
the loop, but still having no luck with the looping insert.
Now it just skipping the insert all together because the Form#i# is
apparently no existant. Even though if I look through the HTML source code,
it is defined and the element name and value are correct. This needs to be
done today and I am no where closer that when I stated.
The funny part is that I used the same coding as I did on another site of
mine and that one works perfectly.
I am down to this:
FORM:
<cfset i = 0>
<cfset i = i+1>
<tr>
value="#i#">
</div></td>
<td width="81%">#optionList.listName#</td>
</tr>
</table>
</cfloop>
INSERT
<cfif IsDefined("Form.list#i#")>
<cfif evaluate("form.list#i#") NEQ "">
INSERT INTO Optouttable (email, outoption)
VALUES ('#Form.email#', '#form["list" & i]#')
</cfquery>
</cfif>
</cfif>
</cfloop>
</cfif>
Have you put <cfdump var="#form#" at the top of your action page. It
would show you EVERYTHING that the is being submitted by the form and
EXACTLY how it is named as well as all the values submitted.
<cfinput name="list#i#" ...> is NOT going to create something named
"Form#i#" It is going to create something named "Form.list#i#". Now
you would need to evaluate that string or my preferred method,
#form["list" & i]#.
If you had a <cfdump var="#form#"> you would have seen just what was
submitted, a bunch of fields as below in a pretty blue table.
list1 = foo
list2 = bar
list3 = something
ect
ect
ect
This is going to give you the same value for every checkbox, which is probably not your intent.
Participant ,
The one issue with doing:
Is that you will still need to check for each form field's existence before trying to use it.
One other option, and this is assuming the check-boxes are all related, is to name all the form fields the same:
<input name="myList" type="checkbox" id="list#i#"
When you have 2 form fields with the same name, and both contain values, they are passed to the action page as a comma delimited list.
Then on the action page, you could add <cfparam name="form.myList" default='' /> to the top, and then insert using a loop:
<cfloop list="#form.myList#" index="i">
do stuff
</cfloop>
"Have you put <cfdump var="#form#" at the top of your action page. It would
show you EVERYTHING that the is being submitted by the form and EXACTLY how
it is named as well as all the values submitted."
I tried that and posted this in an earlier post:
"Now when I dump I am getting nothing......"
'Now you would need to evaluate that string or my preferred method,
"#form["list" & i]#."'
When I enter <cfif evaluate ("#form["list" & i]#") NEQ ""> or <cfif evaluate
(#form["list" & i]#) NEQ ""> I get this error:
'Element list1 is undefined in a Java object of type class
coldfusion.filter.FormScope referenced as'
It refers me to the <cfif evaluate ("#form["list" & i]#") NEQ "">
"If you had a <cfdump var="#form#"> you would have seen just what was
submitted, a bunch of fields as below in a pretty blue table."
I get the same error:
Again, here is my form code:
<cfoutput>
<b>#URL.email#</b>
Please check the boxes of the email types you would like to unsubscribe
<cfset i = i+1>
value="#optionList.listid#">
</cfloop>
input name="email" type="hidden" id="email" value="#URL.email#" />
input name="Update" type="submit" id="Update" value="Update Subscription
List">
</cfoutput>
</form>
What is going wrong in my list to not pass anything?
If nothing, here is my insert code block...what is wrong there?
<cfif evaluate (#form["list" & i]#) NEQ "">
VALUES ('#URL.email#', '#form["list" & i]#')
</cfquery>
</cfif>
</cfloop>
</cfif>
This is actually what I have. And the other version was the same but I had
to change the value. Itstill game my value the unique value and the loop did
give me unique names:
<cfset i = 0>
<cfset i = i+1>
value="#optionList.listid#">optionList.listName#
</cfloop>
I found a great simple tutorial on how to do this with a multiple select box
and I have done this with file upload fields, but check boxes are a pain.
Is there ANYWHERE a coldfusion version of a tutorial or example?
This is the first time you have showed us the <form ...> tag. Your
method is "get". This means that all values on the action page will be
in the URL scope. So do <cfdump var="#url#">. If you changed the
method to "post", then the values will be in the form scope. <cfdump
var="#form#>
You do not do both evaluate and array notation, you do one or the other.
Either
evaluate("form.list#i#") <!--- using the evaluate function --->
OR
#form["list" & i]# <!--- using array notation of complex variables types
There is an example in the thread I referred you to at 09/28/2006 04:16:13 PM
Documentation
