3 Replies Latest reply on Feb 16, 2012 8:55 AM by mike.almond
    Pixel bender Vignette circle to elepsis
    WChristian
      Hi Everyone, Im pretty new to PB and am tweaking a file to use in a Flash project. My problem is creating a new paremeter which distorts the circular vignette to an eleptical one. Increasing the blurWidth Size should increase the width (not height) of the focal point making it wide, can anyone point me in the right direction? Many thanks Code so far is below.
      <languageVersion : 1.0;>
      kernel ZoomBlurFocus
          namespace : "com.abril";
          vendor : "Daniel Allegretti";
          version : 1;
          description : "Ajustable zoom blur, you can control focal size, edge hardness and light. Based on ZoomBlur by Ryan Phelan.";
          parameter float amount
              minValue:0.0;
              maxValue:0.5;
              defaultValue:0.25;
          parameter float2 center
          minValue: float2(0.0);
          maxValue: float2(900.0);
          defaultValue: float2(200.0);
          parameter float focalSize
          minValue: 0.0;
          maxValue: 500.0;
          defaultValue: 100.0;
          parameter bool invert           // TODO: nada de boolean
          defaultValue: false;
          parameter int invert
          minValue: 0;
          maxValue: 1;
          defaultValue: 0;
          parameter float vignette
          minValue: 0.0;
          maxValue: 1.0;
          defaultValue: 0.6;
          parameter int blurWidth
          minValue: 0;
          maxValue: 2;
          defaultValue: 1;
          parameter float edgeHardness
          minValue: 0.0;
          maxValue: 1.0;
          defaultValue: 0.0;
          input image4 src;
          output pixel4 dst;
          void evaluatePixel() {
              float str = 1.0 - vignette;
              float2 coord = outCoord();
              float cur_radius = length(coord - center);
              pixel4 color = sampleNearest(src, coord);
              int cond1 = (cur_radius > focalSize) ? 1 : 0;
              if(invert == 1) {
                  //cond1 = !cond1;
                  if(cond1 == 0) {
                      cond1 = 1;
                  } else {
                      cond1 = 0;
              float strength;
              if(invert == 1) {
                  strength = cur_radius / focalSize;
              } else {
                  strength = focalSize / cur_radius;
              float tmpAmount = strength * amount;
              coord -= center;
              pixel4 tmpDst = float4(0.0);
              float scale;
              scale = 1.0;
              tmpDst += sampleNearest( src, coord*scale + center );
              scale = 1.0 + tmpAmount * (1.0/14.0);
              scale = 1.0 + tmpAmount * (2.0/14.0);
              scale = 1.0 + tmpAmount * (3.0/14.0);
              scale = 1.0 + tmpAmount * (4.0/14.0);
              scale = 1.0 + tmpAmount * (5.0/14.0);
              scale = 1.0 + tmpAmount * (6.0/14.0);
              scale = 1.0 + tmpAmount * (7.0/14.0);
              scale = 1.0 + tmpAmount * (8.0/14.0);
              scale = 1.0 + tmpAmount * (9.0/14.0);
              scale = 1.0 + tmpAmount * (10.0/14.0);
              scale = 1.0 + tmpAmount * (11.0/14.0);
              scale = 1.0 + tmpAmount * (12.0/14.0);
              scale = 1.0 + tmpAmount * (13.0/14.0);
              scale = 1.0 + tmpAmount * (14.0/14.0);
              tmpDst /= 15.0;
              if (cond1 == 1) {
                  dst = ((1.0 - edgeHardness) * ((color * strength) + (tmpDst * (1.0 - strength)))) + (tmpDst * edgeHardness);
                  dst.rgb = ( vignette * dst.rgb * strength ) + ( dst.rgb * (1.0 - vignette) );
              } else {
                  dst = color;
              dst.a = color.a;
