I was testing Flash Builder 4.5 to build an Android App.
Everything was fine until I tried to deploy it to my Android Pad.
I got the following error message,
Error |
'Launching mobiletest' has encountered a problem. Error occured whil installing the application: pkg:/data/local/tmp/mobiletest.ask Failure [INSTALL_FAILED_INVALID_APK] 2324 KB/s (1637749 bytes in 0.688s) |
I googled around but just didn't get the answer to this in Flash Builder.
Please help and Thanks in advance!
Chew HG
Did you try to redo the export process a second time just to be sure?
Did you set the permissions your app need in the xml file of your project?
Try doing an export release build and generate an apk. Now try doing a manual install using "adb install <apk_name>".
Does this work ?
Do you have AIR installed on your device? Make sure your Andriod pad comes under Adobe's certified devices
http://www.adobe.com/flashplatform/certified_devices/tablets.html
Ramesh
