I had just posted this in the flex forum and then realized there was a Flash Builder Forum where this question might be more suited so I appologize for the double post.
I have built a flex application using Flash Builder 4.6. It utilizes ColdFusion Flash Remoting for its data services. When first setting up the data services I had to set a bunch of properties in the flex server section. Which I am not sure are all correct but the app does run and connect to the data services. They were:
Application Server type: ColdFusion
Use remote object access service
ColdFusion flash remoting
Server Location:
Deployed to Java application server
Web Root: v:\inetpub\testFlex
Root URL: http://myDevServerIP/
ColdFusion Was folder: v:\CF9\JRun4\servers\testFlex\cfusion.ear\cfusion.war
My question is now when I'm ready to deploy to my production machine and load the app onto a tablet or other computer, obviously the Root URL will be different something like http://myLiveURL.com. Is this the only thing I change? Do I even change it here or is there some other location? Any other things I need to change?
Your help is much appreciated!
So I tried modifying the root url to be my live production url and it broke. I can no longer test the data services nor run the app. I did notice that the _Super_XXX.as file no longer had an endpoint so I edited that file and then was able to run the app however I cannot test any of the dataservices any more. I get an error:
InvocationTargetException: There was an error while invoking the operation. Check your server settings and try invoking the operation again. Reason: java.net.MalformedURLException: no protocol.
And then even if I try and set it back to my development server I still get this error.
How can I do development on my development server then test it on my test server then deploy it to an app on a tablet that then would point to a production server for the data all the while being able to go back to doing more development on the development server?
Please help! I'm stumped!
