I have checked the quizzes in my course a thousand times, and I am positive they are set up right (see below for setup). But I still get random crashes at quiz slides while viewing the presentation. Any ideas about what is wrong? Could it have anything to do with hidden slides? Is there some time-out value that I need to set? Is this a problem with lengthy courses (mine is 150 slides)?
There is no video or audio in the slides.
Quiz design: If the answer to quiz A is wrong, the presentation sends you to the slide that precedes quiz A, which is a hidden review slide. You read the review and then advance to the quiz again. If the answer to quiz A is right, you are advanced two slides ahead, to quiz B--this skips you over the (hidden) review slide for quiz B.
Can you please verify whether you are seeing a "halt" or a "crash" ?
If its a crash, are you seeing any exception thrown or an error thrown or the browser getting closed (not responding)??
If its a halt, are you not able to move back or forh or are you not able to relaunch it ??
Pavan
Hi Kumar,
It is a halt. As soon as I select an answer on the quiz page, the presentation appears to stop running. I don’t get any acknowledgement response, and I can’t scroll to a previous page. If I click the refresh button in my browser (firefox), the presentation re-launches from slide 1.
thanks, Becky
Hi Becky,
I am not able to reproduce this issue on my system.
Do you see the same issue on launching the viewer.swf ?? try running it on different browser as well
Also if you could share the presentation, it would be helpful to find the issue.
Pavan
