Ok, i am beginning to see. I am looking at the cfloop list in
the docs.
So I need to replace the 'form.fieldname' with the actual
field 'list'?
How can I replace that with the name of 'list' since it is
incrementing
from the form?
Do I need to rename my fieldname in the form from list#i# to
something
static?
NO, you just need to put all the pieces together.
Look at the <cfdump var="#form#"> you posted earlier.
struct
EMAIL wmkolcz@avemarialaw.edu
FIELDNAMES LIST1,LIST2,EMAIL,UPDATE
LIST1 9999
LIST2 1
UPDATE Update Subscription List
See the third line, there is a "field" named "FIELDNAMES" and
it
contains a list of all the fields that where submitted by the
form page.
<cfloop list="#form.fieldnames#" index="field">
This is going to loop over the list in the form.fieldnames
key
[LIST1,LIST2,EMAIL,UPDATE] and put each list value into the
variable
"field".
<cfif left(field,4) EQ "LIST">
This checks the value of the variable "field" in each loop to
see if it
starts with the string "LIST" thus this is one of the list
check box fields.
VALUES ('#form.email#', #form[field]#)
This inserts the values of form.email and the list field into
the
database. In each loop itteration #form[field] is going to
resolve to
form[LIST1] and form[LIST2] which in turn will resolve to the
following SQL
VALUES ('wmkolcz@avemarialaw.edu', 1)
VALUES ('wmkolcz@avemarialaw.edu', 9999)
