MemphisMatt,
This is the standard RH code for displaying the panes. I
don't see how it could be a source of trouble.
First, let's make sure I have this straight.
You are using RH 4.x to generate Webhelp on an XP machine.
You are using Interent Explorer at least V 5.5. Any earlier
IE browser will have problems But if you have XP, you must have the
current IE browser. If you are using a browser other than IE, you
will have problems that can be solved.
As I understand your situation,
1. You generate a WebHelp project, but when you open the
version stored on your hard drive in IE, it doesn't work. This is
normal with XP -- If WebHelp is on a local hard drive, XP will
interfere. However, XP should not interfere with WebHelp stored on
a server, so long as your security settings are not at the highest
level.
2. You publish the WebHelp to a server. Everyone else can
open it up with TOC, etc., with IE. At this point, I'm not sure
what comes next in your situation:
(a) You cannot open it up with TOC, etc., from the server
using IE. Are you certain you are accessing it from the server and
not from your hard drive? Are your XP Internet security settings
too high? If everyone else can open it from the server, the problem
is not in the WebHelp output.
(b) You can open it with TOC, etc., on the server, but still
can't when you try to access the WebHelp stored on your hard drive.
See No. 1, above.
(c) You can open every other WebHelp package stored on the
server with IE, but not this one in IE. If this were true for other
users, I could suggest where to look. But since you say everyone
else can open it with TOC, etc., in IE, the finger points to your
PC.
Please clarify.
Harvey
