1. Re: multiple audio channels (languages) in 1 video?
Harm Millaard Jan 25, 2012 2:25 PM (in response to Bucketheadd)Use Encore for that. PR can't do it.
2. Re: multiple audio channels (languages) in 1 video?
Bucketheadd Jan 25, 2012 2:42 PM (in response to Harm Millaard)Well, I don’t want a dvd or menu. Just a way for someone to select a different language through a video player setting. Is there a way to export .MKV’s?
From what I’ve read on here, this is a near impossible thing to do….like to have an .mkv that end users can switch languages because .mkv’s are rare and require certain codecs and players that people would have to install.
3. Re: multiple audio channels (languages) in 1 video?
Harm Millaard Jan 25, 2012 2:46 PM (in response to Bucketheadd)Put each language version in a separate file and link to that, based on a language choice on your website or use IP adresses to default to a certain language.
4. Re: multiple audio channels (languages) in 1 video?
Bill Hunt Jan 25, 2012 3:03 PM (in response to Bucketheadd)Well, one thought would be to author in Encore to a Flash DVD, and use that code/files on the Web site.
Flash will give you the interactivity, that you need, where a standard AV file will have no interactivity. That must come from elsewhere.
Or, use Harm's suggestion in Reply # 3.
Good luck,
Hunt
5. Re: multiple audio channels (languages) in 1 video?
JSS1138 Jan 25, 2012 10:35 PM (in response to Bucketheadd)a way for someone to select a different language through a video player setting.
Adobe software isn't capable of this. You'll need to export out the video, and then each audio track separately. Then find some other program to combine them into one file that software players can work with, allowing the viewer to choose his language.
6. Re: multiple audio channels (languages) in 1 video?
Bucketheadd Jan 26, 2012 8:37 AM (in response to Bill Hunt)Thanks for the suggestion. I just read Encore’s help and they say:
“Flash does not have all of the features that DVDs have, such as multi-page menus or playing from multiple audio tracks in a timeline. Flash output does not support user operations.”
So I suggest doing what Harm said and just making multiple videos.
Thanks again for the info. Just trying to clear this up for anyone else in the future that sees this.
7. Re: multiple audio channels (languages) in 1 video?
Bill Hunt Jan 26, 2012 8:40 AM (in response to Bucketheadd)Hm-m-m, missed the Multiple Audio Tracks in Encore Flash. Guess that I was thinking of Sub-titles, that translate to that format.
Thank you for pointing out that limitation - learned something new. Scratch the Encore Flash theory. Sounds like Harm's method is the one to go with.
Good luck,
Hunt
8. Re: multiple audio channels (languages) in 1 video?
Pharther Phurther Jan 30, 2012 10:45 PM (in response to JSS1138)Interesting .. This should be another feature request.
9. Re: multiple audio channels (languages) in 1 video?
EuroSiti Feb 24, 2012 6:08 AM (in response to Bucketheadd)It's no big deal to play MKV files. Anyone can download the universal VLC media player which doesn't require any codec installation.
If users insist on their 'own player', they should simply download either:
Haali Media Splitter or Combined Comminuty Codec Pack.
If they use a standalone media player, anything from Samsung will normally play MKV files without complaining. Many devices (except Sony, Apple and Canon products) generally support MKV files to some extent.
But if your recipients are using 'conservative' hardware, you should use the MP4 contaier instead.
Use Handbrake, Freemake or (even better) MKVtoolnix to add multiple audio tracks, extra selectable subtitles or add chapters to the video file. All of these features are supported by VLC, Media Player Classic and (possibly) also BS Player.
If you have an existing DVD you want to convert to a file while still preserving the structure, use MakeMKV.
