We create forms as PDF's that we publish on our WEB site. We also have vendors that produce the same documents with 2D barcodes as PDF's. We scan/image the returned doucuments and run OCR, ICR and 2D interpretation of data. When the public prints the documents in Adobe Reader with scaling set to none (or actual size in Reader X), everything is fine. The issue is when the the users leave the size option set to something other than none or actual. We have margins over 1/2 inch on all sides and the pages will always scale. This moves the exact positioning of the fixed print documents and shrinks the 2D barcodes to where they are unreadable. We have the page scaling set to none in the document itself but of course the user can always override.
I have been told that if you change the size of the page to something less than 8 1/2 by 11, you can prevent the scaling. I have played with this and found that what works best for a laser printer is different than what works with an inkjet. Does anyone know a size that will prevent scaling on the most printers?
Is there any other way to prevent a PDF document from scaling? I have even created a PDF with one word in the middle of am 8 1/2 by 11 page and it will still scale.
If you are selecting anything other than None/Actual, then aren't you actually stating that the page needs to be scaled depending on the option chosen.
Yes, that is true. The issue is that the general public is printing these forms. I'm am looking for a solution where the form will never scale even if the user changes the setting to something other than None/Actual.
I doubt that can be case, since the settings provided while printing will always be honored.
One solution is to declare the page size as smaller than 8 1/2 by 11. I have experimented and determined that a size of 8.13 by 10.63 will never scale on my laserjet but will scale on my inkjet. What answer that I'm looking for is if anybody knows a size that would not scale on "most" printers.
Does anyone have any thoughts on this matter. We already set the pagescaling to none in the document, but it appears that people like to override this setting.
(Optional; PDF 1.6) The page scaling option to be selected when a print dialog is displayed for this document. Valid values are None, which indicates that the print dialog should reflect no page scaling, and AppDefault, which indicates that applications should use the current print scaling. If this entry has an unrecognized value, applications should use the current print scaling. Default value: AppDefault.Note: If the print dialog is suppressed and its parameters are provided directly by the application, the value of this entry should still be used. |
Have you tried Adobe LiveCycle Designer? There is an option under File > Form Properties > PDF Print Options to tick a box to prevent a user from overriding the page scaling option. This seemed to work for me.
Hi Jim,
Do you know the name of the field or property that you are setting? I do not have LiveCycle, but it must be setting some property in the PDF file.
Dave
Dave, I don't know the name of the field. I just downloaded the thirty day free trial of LiveCycle and used that...
