1. Re: Need help reading the info from GSpot...
Bill Hunt Jan 27, 2012 8:34 AM (in response to davidbeisner2010)David,
You might get more useful info from MediaInfo, than G-Spot, with that/those file(s).
I also find that the Properties utility in QT Pro (Ctrl+J), does better with MOV files.
Good luck,
Hunt
2. Re: Need help reading the info from GSpot...
davidbeisner2010 Jan 27, 2012 8:48 AM (in response to Bill Hunt)Thanks, Bill... here's the info from MediaInfo (I don't own QT Pro):
General
Complete name : F:\PCI\MLK\MLK Day 2012\Barber_MLKDay_sans_music.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 3.31 GiB
Duration : 4mn 32s
Overall bit rate mode : Variable
Overall bit rate : 104 Mbps
Encoded date : UTC 2012-01-20 00:24:50
Tagged date : UTC 2012-01-27 16:13:10
Writing library : Apple QuickTime
©TSC : 2997
©TSZ : 100
Video
Format : Intermediate Codec
Codec ID : icod
Codec ID/Hint : Apple
Duration : 4mn 32s
Bit rate mode : Variable
Bit rate : 103 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 1.655
Stream size : 3.26 GiB (99%)
Language : English
Tagged date : UTC 2012-01-20 00:31:22
Color primaries : BT.709-2, SMPTE 274M, SMPTE 296M
Transfer characteristics : BT.709-2, SMPTE 170M, SMPTE 274M, SMPTE 293M, SMPTE 296M
Matrix coefficients : BT.709-2, SMPTE 274M, SMPTE 296M
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 4mn 32s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 49.9 MiB (1%)
Language : English
Menu
Duration : 4mn 32s
Language : English
Encoded date : UTC 2012-01-20 00:31:22
3. Re: Need help reading the info from GSpot...
Bill Hunt Jan 27, 2012 8:54 AM (in response to davidbeisner2010) -
4. Re: Need help reading the info from GSpot...
davidbeisner2010 Jan 27, 2012 8:56 AM (in response to Bill Hunt)Thanks, Bill... I'll have to take the file over to our Mac lab and work on it there... I wonder if PrPro on the Mac will open it? We'll find out!
5. Re: Need help reading the info from GSpot...
Bill Hunt Jan 27, 2012 9:49 AM (in response to davidbeisner2010)David,
That is a good question, and I cannot answer it. Not sure if that CODEC can be used by PrPro, on a Mac. I'd see if one of your Macs has it (might ONLY work in FCP?), and give it a try. Might have to go back to FCP and be Saved with some other CODEC.
Please report what you find in the Mac lab, as I will certainly learn something.
Good luck,
Hunt
6. Re: Need help reading the info from GSpot...
davidbeisner2010 Jan 27, 2012 10:09 AM (in response to Bill Hunt)FYI, PrPro did read the file just fine on the Mac… exported out using a
cross-platform codec, so I’ve got a version I can work with on my PC.
Thanks for the help!
7. Re: Need help reading the info from GSpot...
Bill Hunt Jan 27, 2012 11:11 AM (in response to davidbeisner2010)Great news!
Thanks for reporting your success.
Good luck,
Hunt
