cfloop over dynamically generated check boxes and radio buttons
Jan 26, 2012 Jan 26, 2012
Hello, I have a page where a user can select a project, via a checkbox then select a radio buttion with the following options "Support, Oppose, Not Known". The form fields are dynamically generated, can be anywhere from 1 to many. here is a screenshot:
A user has to at least select 1 but can select many. The checkbox names are dynamically generated and follow this naming convention:
f_project_1
f_project_2
the radio buttons are named similar:
f_support_1
f_support_2
So, on my submit page I need to loop through each of these and insert into my database. before I just had a select box with projects(no support, oppose stuff) and I used the following code and it worked great.
<CFLOOP INDEX="projectlist" LIST="#Form.f_project#">
          <cfoutput>
                    <CFQUERY  datasource="#datasource#" name="insertproject">
                              INSERT into contactrecord_project
                              (contactrecord_project_id,
                              contactrecord_project_nm,
            project_support)
                              Values ('#newid#','#projectlist#',)
                    </CFQUERY>
          </cfoutput>
</CFLOOP>
I'm just brain dead today, can someone please help me out with looping over the list and getting it inserted into my database
Advanced techniques
3.5K
<cfdump var="#form#">
<cfform>
Proj 1: <cfinput name="f_project_1" type="checkbox">||
Support 1: <cfinput name="f_support_1" type="radio" value="support11">|
Support 1: <cfinput name="f_support_1" type="radio" value="support12">|
Support 1: <cfinput name="f_support_1" type="radio" value="support13" checked="yes">|
<br>
Proj 2: <cfinput name="f_project_2" type="checkbox">||
Support 2: <cfinput name="f_support_2" type="radio" value="support21">|
Support 2: <cfinput name="f_support_2" type="radio" value="support22">|
Support 2: <cfinput name="f_support_2" type="radio" value="support23" checked="yes">|
<br>
Proj 3: <cfinput name="f_project_3" type="checkbox">||
Support 3: <cfinput name="f_support_3" type="radio" value="support31">|
Support 3: <cfinput name="f_support_3" type="radio" value="support32">|
Support 3: <cfinput name="f_support_3" type="radio" value="support33" checked="yes">|
<br>
<cfinput name="sbmt" type="submit" value="send">
</cfform>
<cfloop from="1" to="6" index="idx">
    <cfset projectName = "f_project_" & idx>
    <!--- Do something (for example, an insert) only if a project is selected on the form. Otherwise, do nothing. --->
    <!--- Note: Checked radio buttons return value, however checked checkboxes only return "ON" --->
    <cfif structKeyExists(form,"#projectName#")>
        Your insert query goes here. The values to insert are: <br>
        <cfoutput>Project name: #projectName#; Support: #form["f_support_" & idx]#</cfoutput><br>
    </cfif>
</cfloop>
Jan 27, 2012 Jan 27, 2012
Hey BKBK.....How can I get only the number into the projectname variable? Right now it is inserting "f_project_1" for example....I just want "1"
Thanks.
BKBK's answer gave you the value of the formfield.  If you run this code:
<cfdump var = "#form.f_project_1#">
what do you see?
Hi Dan, Here is my code for  the dynamic creation of the checkboxes & radio buttons
<cfloop query="getprojects">
                           <tr>
                     <td bgcolor="##CCCCCC"><input type="checkbox" name="f_project_#project_name_id#" value="#project_name_id#" id="f_project_#project_name_id#"  onClick="javascript:enableField_#project_name_id#()">#project_name#</td>
                   <td bgcolor="##CCCCCC"><input name="f_support_#project_name_id#" type="radio" value="1" id="f_support_#project_name_id#" disabled></td>
                   <td bgcolor="##CCCCCC"><input name="f_support_#project_name_id#" type="radio" value="0" id="f_support_#project_name_id#" disabled></td>
                   <td bgcolor="##CCCCCC"><input name="f_support_#project_name_id#" type="radio" value="2" id="f_support_#project_name_id#" checked disabled></td>
                  </tr>
          </td></tr>
          </cfloop>
So If I dump the form variable f_project_1 it = 1
BKBK's code does not appear to me to use the value created from the form(I did not provide that code when I first created this thread)....he sets it with   <cfset projectName = "f_project_" & idx>
Thanks for any assitance you can provide.
Jan 28, 2012 Jan 28, 2012
                           <tr>
                     <td bgcolor="##CCCCCC"><input type="checkbox" name="f_project_#project_name_id#" value="#project_name_id#" id="f_project_#project_name_id#"  onClick="javascript:enableField_#project_name_id#()">#project_name#</ td>
                  </tr>
          </td></tr>
          </cfloop>
I assumed the project names to be f_project_1, f_project_2, and so on. That is what your "naming convention" said.
In any case, your code appears to have done most of the work already. My suggestion should now read:
        <cfoutput>
          Project ID: #idx#;
         </cfoutput><br>
    </cfif>
</cfloop>
Thanks BKBK...that did it....I appreciate you getting back to me.
Jan 30, 2012 Jan 30, 2012
OK
Documentation
