This may be helpful for others referencing this post who would like to change the icon image that RoboHelp uses by default.
To place an image in the browser tabs, address bar, and favorites lists, RoboHelp uses a file called whstart.ico instead of favicon.ico. If you overwrite this file in Program Files with your desired ico image (titled exactly the same, whstart.ico), RoboHelp will use your new icon image when generating and publishing projects.
By default my whstart.ico file was installed in the following location:
C:\Program Files\Adobe\Adobe RoboHelp 8\RoboHTML\WebHelp5Ext\template_skin
If you change the icon in Program files, the new icon will be used every time you generate webhelp. If that is what you want, that's the way to do it.
If you want different icons for different projects, generate the webhelp and replace the whstart.ico in that output. It will get overwritten each time you generate so keep a copy.
The program files method is the easiest and I just offer this for those of you who need different icons.
