27 Replies Latest reply on Feb 19, 2012 8:07 AM by Rotaluclac
    Entire computer temporarily hangs during LR startup
    Rotaluclac Level 1
      When I start Lightroom 3.6, my entire computer locks up for 20 to 30 seconds. The hard disc light continuously lights - that's all.
      I tried starting Task Manager before starting Lightroom to view the CPU usage - but the display just freezes, so Task Manager completely misses the time during which Lightroom is starting up.
      The Event Log doesn't show anything special (or I don't know what to look for).
      Even pressing the Capslock key has no effect - the indicator on the keyboard won't light up until Lightroom has finally started (that is, after 20 to 30 seconds).
      After this initial delay, all is well.
      What could be causing this nuisance?
      (Vista Ultimate 64bit completely updated, 6GB, no virus checker except Microsoft Security Essentials and Spybot S&D, LR cache 25 GB, 300 GB free disc space, LR catalogue optimised, almost 5000 pictures in LR database)
        • 1. Re: Entire computer temporarily hangs during LR startup
          Hal P Anderson Level 6
          Lots of information. Thanks.   I don't know what's wrong, but you can try a few things.
          I'd try excluding my images, catalogue, and preview cache from the virus checker.
          You also might try running a disk checker against your disks.
          Also, sometimes USB devices that are plugged in can cause long lock-ups. Bluetooth can be a culprit.
          And finally, I'd try renaming my preferences file and see if that fixes the problem. It often does in strange situations. Find it here.
          Let us know how it works out.
          Hal
          • 2. Re: Entire computer temporarily hangs during LR startup
            jiten rai
            check the system requirment of lightroom from the adobe website and then check the same of your system
            if not
            >un-install lightroom and then disable all the sequrity features and then install it
            • 3. Re: Entire computer temporarily hangs during LR startup
              Rotaluclac Level 1
              I just tried most of your suggestions. This is what I did:
              - Disable all virus checkers.
              - Check disks. Result: they are okay.
              - Unplug USB hub.
              - Start Resource Monitor.
              Then I started LR and timed it. Result: as before, an unresponsive system, hard-disc light continuously on. Time before LR showed on screen: 25 seconds. Time before LR was usable: 26 seconds (from start).
              Resource Monitor showed that LR has been reading LOTS of data from LOTS of files.
              Next I closed LR, waited a while, then started LR again. Now, the timing was completely different. Time before LR showed on screen: 2 seconds. Time before LR was usable: 3 seconds (from start). Perhaps both times were even a bit less - anyway, I find these startup times totally acceptable.
              Resource Monitor showed that LR has only been reading a very limited number of files.
              So the slowness and the unresponsiveness only occur when starting LR the first time; after that, all is well.
              Any idea as to the cause? It doesn't look like renaming the preferences file would help, though I could try that - but I would have to reboot my computer first, because now LR does start quickly.
              • 4. Re: Entire computer temporarily hangs during LR startup
                Weird. So the first run of LR freezes your machine for 25 seconds or so, and subsequent runs work normally.
                Win 7 probably caches data that it reads from disk and uses the cache later if needed, but normal disk I/O shouldn't lock up your system. I've seen total system lockouts when Win 7 was installing a device driver, but that seems unlikely.
                On your file menu, there's an Optimize catalog entry. Probably worth a try.
                If the slow startup continues to bug you, try renaming the Prefs file, re-booting, and starting LR. I've seen it work when I totally doubted that it would.
                And I suppose it's possible that there's a problem with your preview cache.The site I point to in my previous post will show you where it is. You could try renaming that and then rebuilding all your previews (menu:  Library->Previews->...).
                Hal
                • 5. Re: Entire computer temporarily hangs during LR startup
                  Rotaluclac Level 1
                  Yes, it's only the first run that freezes the computer for about 25 seconds.
                  By the way, it's not Win7, it's Vista Ultimate 64bit.
                  The lock-up isn't complete - the mouse pointer still moves with the mouse. But any mouse clicks only take effect after the 25 seconds lockup. Keyboard does not work during that time - even the Capslock, Scrolllock and Numlock lights only react after the 25 seconds are over.
                  I renamed the prefs file. The lockup still occurred, only now LR started asking me some configuration questions - which could of course be expected when the prefs file is missing.
                  Catalog was already optimised, so that doesn't cause this.
                  I'll try renaming the preview cache - please wait a few minutes until I post the result.
                  ---  edit after trying  ---
                  I moved the preview cache to a different location and rebooted. I then started Lightroom again - the startup time was only 6 seconds instead of the usual 25! A second startup took the usual 3 seconds.
                  I then generated standard-size previews (no 1:1 previews), which took a while. Then I rebooted again and started Lightroom again. This time, the system was unresponsive again, and starting took a generous 36 seconds - which is even more than the 25 seconds it took before. A seconds startup took the usual 3 seconds again.
                  So it looks like the enormous first-startup time is caused by my preview cache. Can this knowledge somehow help in finding a solution?
                  • 6. Re: Entire computer temporarily hangs during LR startup
                    Stranger and stranger. With no preview cache, startup was relatively quick. With one, the first startup is very slow. Rebuilding the cache didn't fix what was wrong. And Lightroom is the only thing running during that startup time.
                    The only thing I can think of beyond all my previous ideas is to create another catalogue from the one you have. Either you can create a new catalogue and import from your current one, or export a new catalogue directly from your current one. The idea is that this will leave all the bad karma behind. IIRC, one of those options has a chance of working, and the other doesn't. I can't remember which, but I suspect that importing from your current catalogue (option #1) will have the best chance of being helpful, so I'd try them in that order. Your catalogue is relatively small, so if won't cost you a lot of time. If it works, you'll have a new, well-behaved catalogue, and you can move things around on disk (or rename). If not, we'll have to think harder.
                    Just out of curiosity, what kind of drive is your catalogue (and previews) on?
                    Hal
                    • 7. Re: Entire computer temporarily hangs during LR startup
                      Rotaluclac Level 1
                      Thanks for your reply!
                      I tried both suggestions. I first created a new catalogue and imported the old one into it. Reboot, start Lightroom - and it was slow again (30+ seconds startup time).
                      I then took the newly created catalogue, and exported it to a third catalogue. Reboot, start Lightroom - same result, 30+ seconds startup time. Quitting and restarting Lightroom took only a few seconds.
                      So neither method worked...
                      My catalogue is on an internal Seagate Barracuda 750GB disc (type number ST3750525AS), 7200 rpm. This disc has three partitions: one for the OS, one for the installed programs, and one for data. All Lightroom stuff is on the data partition. All partitions are NTFS formatted.
                      • 8. Re: Entire computer temporarily hangs during LR startup
                        I'm running out of ideas.
                        You could try re-installing LR. I'm not optimistic about your chances of an improvement, but it's generally pretty quick, and it would be good to eliminate that as a possible solution.
                        How long has LR been misbehaving? Did it slowly get worse as you added images to your catalogue? Are you running any unusual background tasks?
                        Hal
                        • 9. Re: Entire computer temporarily hangs during LR startup
                          Rotaluclac Level 1
                          I kind-of re-installed LR when I installed version 3.6 as a replacement for 3.5. That was only last December. The problem already existed with 3.5, so I was hoping 3.6 would solve it - but it didn't. Therefore, I do not think a re-installation would help.
                          LR's behaviour slowly got worse. At first I didn't notice. The problem became apparent after I imported a whole bunch of old holiday pictures, which made my database grow from 1000-ish to 3500-ish pictures.
                          The slowness now seems to be proportional to the number of pictures in the preview cache. At 5132 pictures now (I added a few recently), the first start takes 30 seconds. If startup time is linearly proportional to the size of the preview cache, I'm afraid I'd have to split my catalogue at about 10000 pictures or so - which isn't really what I'd have expected.
                          Apart from the firewall and virus scanners I mentioned (and disabled to test), I'm not aware of any background task.
                          • 10. Re: Entire computer temporarily hangs during LR startup
                            I asked some very knowledgeable friends for suggestions.
                            One thought that perhaps your partitioned drive might be a problem. He suggested that you copy your catalogue and previews to an external drive, open the catalogue there, and see if that helps. If not, you can just delete the copies. Anyway, you won't have to relink your images to the new catalogue since all of them will continue to be where they already are. Don't actually make changes to the new catalogue, just see if startup times are back to normal.
                            Hal
                            • 11. Re: Entire computer temporarily hangs during LR startup
                              Rotaluclac Level 1
                              I found a different way to get startup times back to normal!
                              During all previous tests, after each reboot, I first did some other stuff, then closed all programs and started Lightroom. This resulted in long startup times.
                              This time, I just rebooted, logged into Windows, and let the computer be idle for half an hour. Not even the screensaver was active - I disabled it.
                              After these 30 minutes, I started Lightroom without having started any other program. Lo and behold - the startup time was just a few seconds!
                              I then rebooted, and viewed some webpages in Firefox, without starting any other program. I then closed Firefox and started Lightroom - and found that the startup time was over 30 seconds.
                              I repeated the test with a different program: reboot, edit some ASCII files in UltraEdit, close UltraEdit, start Lightroom. Startup time: over 30 seconds.
                              Same test with Excel: reboot, edit some Excel spreadsheet, close Excel, start Lightroom. Startup time: less than 10 seconds.
                              Start Firefox again, view some webpages, close Firefox, start Lightroom - startup time about 5 seconds.
                              So it seems that some programs seem to cause the long startup times of Lightroom, even if they are closed after having been used. Firefox and UltraEdit do, Excel does not. But these programs only cause problems if Lightroom has not been started before these programs were used. If Lightroom has been used before, these ill-behaved programs may be used without affecting Lightroom's startup time.
                              Are you still with me with this complex description?
                              I'm very, very puzzled now.
                              • 12. Re: Entire computer temporarily hangs during LR startup
                                Geoff the kiwi Adobe Community Professional & MVP
                                Do try the solution offered by Hal above, I'm sure your partioning will be the answer, too much attempted access to the one drive simultaneously.
                                • 13. Re: Entire computer temporarily hangs during LR startup
                                  Rotaluclac Level 1
                                  I didn't try that solution because I think the partitioning is not the reason for the problem.
                                  First, Lightroom will access the same files anyway, whether they are on a single partition or on different partitions.
                                  Second, the problem does NOT occur if Lightroom is the first program to be run after starting Windows, or if I first run Excel for a while, and then start Lightroom. The problem also does NOT occur if I run Lightroom for the second time.
                                  Add to this the fact that partitioning a drive is quite usual, and even recommended practice. Thus, I think partitioning is unrelated to my startup problems.
                                  • 14. Re: Entire computer temporarily hangs during LR startup
                                    All true, but there could be something strange going on with the drive, and putting a catalogue on an external, if you have one, is a relatively cheap experiment. Your choice, of course.
                                    Hal
                                    • 15. Re: Entire computer temporarily hangs during LR startup
                                      Rotaluclac Level 1
                                      Well, you are right - and a simple experiment doesn't hurt.
                                      So I copied the catalogue and the previews to an external drive, which was connected via USB. I moved the original catalogue and previews directory to somewhere else, to make sure Lightroom would be unable to find it. Then I started Lightroom, which of course asked which catalogue to use; I instructed it to use the catalogue on the external drive, and to always use that catalogue (as a preparation for the experiment).
                                      Then I rebooted, did some other stuff using at least Firefox and UltraEdit, closed all programs, and started Lightroom.
                                      Result: a startup time of a little over 35 seconds. A few seconds were due to the external drive having to spin up, so the real startup time would have been in the order of 30 seconds - the same as always.
                                      During the startup time, the hard-disc light was continuously on. The light of the external disc showed only intermittent activity, with long periods of no activity in between.
                                      A second start of Lightroom, still using the catalogue on the external disc (which is now spinning), and being performed as I write this sentence, takes only - wait a sec - less than three seconds.
                                      So - now what? I'm really out of ideas, I must confess.
                                      • 16. Re: Entire computer temporarily hangs during LR startup
                                        "So - now what? I'm really out of ideas, I must confess."
                                        Me, too. The experiment was nicely done, though.
                                        So it's not the drive, the catalogue, the preferences, or any of the other things we investigated.
                                        Are you using any plugins?
                                        Hal
                                        p.s. Do you recall how long it took to copy the previews and catalogue to the external drive?
                                        Message was edited by: Hal P Anderson
                                        • 17. Re: Entire computer temporarily hangs during LR startup
                                          Rotaluclac Level 1
                                          I have the standard plugins that came with Lightroom:
                                          - Canon Tether Plugin
                                          - Facebook
                                          - Flickr
                                          - Leica Tether Plugin
                                          - Nikon Tether Plugin
                                          - SmugMug
                                          All of these are listed as Disabled, with the exception of Flickr, which is listed as "Installed and running". The version of the Flickr plugin is 3.6.0.795620.
                                          Could the cache be an issue? I specified an maximum cache size of 25.0 GB; the current total size of all 2978 files in the CameraRaw cache directory is 21.5 GB. I increased the cache size to the current value because several websites say this would speed up Lightroom's operations; could there be a negative impact of a cache of this size?
                                          • 18. Re: Entire computer temporarily hangs during LR startup
                                            No, the cache size is fine. Mine is 30 GB, and I've heard of people setting it much higher. Mainly, the cache helps speed loading of images in the Develop module. It only needs to be big enough to hold data for your current "working set" of images. Probably both of ours are set bigger than they need to be, but if the space is available, why not use it?
                                            You've presented us with a bona fide mystery, and I've run out of ideas. I'll keep your problem active in background. If I come up with any ideas, I'll come back and ask more questions.
                                            Thanks for patiently putting up with all the questions and experimentation. I'm sorry that we couldn't find a solution.
                                            Hal
                                            • 19. Re: Entire computer temporarily hangs during LR startup
                                              Rotaluclac Level 1
                                              Well, thank you for your patience and all your efforts to understand the cause of this problem!
                                              May I ask you who you are, or is that impolite? I was just wondering whether you are professionally affiliated to Adobe, or whether you are, well, let's call it - a benevolent individual who likes to help others by sharing his knowledge.
                                              Oh, by the way - do you think this would be a bug that I could/should somehow submit to Adobe?
                                              • 20. Re: Entire computer temporarily hangs during LR startup
                                                Not affiliated with Adobe. I guess I'm benevolent. And I like the occasional challenge. I've learned a lot about LR by hanging out here and trying to answer questions.
                                                You could go to the official bug website and submit it. Adobe monitor that one and will at least look at it. Post a link to this thread when you do.
                                                Here's the site: http://feedback.photoshop.com/photoshop_family
                                                Hal
                                                • 21. Re: Entire computer temporarily hangs during LR startup
                                                  Victoria Bampton LR Queen Adobe Community Professional & MVP
                                                  Ok, another test for you (and apologies if I've missed that you've already done this...)...
                                                  Try creating another clean catalog, and import the photos set to 'add at existing location'.  This is only a test to narrow down whether it's possibly catalog-specific - if so, we might be able to beg Dan Tull as he's great with odd issues!
                                                  • 22. Re: Entire computer temporarily hangs during LR startup
                                                    I guess one could also try creating another user and try from there.
                                                    • 23. Re: Entire computer temporarily hangs during LR startup
                                                      Rotaluclac Level 1
                                                      I already did something very similar:
                                                      startup time).
                                                      Is this what you suggested, or did you mean something else?
                                                      • 24. Re: Entire computer temporarily hangs during LR startup
                                                        Rotaluclac Level 1
                                                        Sorry, I do not understand what you mean by "creating another user".
                                                        • 25. Re: Entire computer temporarily hangs during LR startup
                                                          No, I mean a clean catalog without importing the other catalog.  Just do a straight photo import as a test, rather than importing the catalog.  I'm wondering if there's some data in the catalog which is causing a problem.
                                                          • 26. Re: Entire computer temporarily hangs during LR startup
                                                            Rotaluclac Level 1
                                                            Okay, I understand now. So I tried the following:
                                                            First, I created a new catalogue, clicked Import, selected the existing 5132 pictures (those that are already in the current catalogue), and selected to Copy them to the new catalogue. Reboot and so on; result: still a Lightroom startup time of over 30 seconds.
                                                            Then, I created another new catalogue, clicked Import, selected the same existing 5132 pictures, but now I selected to Add (not Copy) them to the new catalogue. Reboot and so on; result: the same as before, a Lightroom startup time of over 30 seconds.
                                                            So the catalogue does not seem to be the problem.
                                                            I also found out that its Lightroom itself, not the catalogue, that's causing the slowness.
                                                            Above, I started Lightroom with the newly created catalogue, and startup times were terribly long. I already knew that quitting Lightroom and starting it again with the same catalogue would be quick (no long startup time). But now, I quit Lightroom, then removed the new catalogue, and started Lightroom again, with the old catalogue. So this was the second time Lightroom started, but the first time the old catalogue was loaded. Lightroom started quickly. Therefore, I suspect the problem is not related to the catalogue, but to Lightroom. But that's of course just a guess.
