1 Reply Latest reply on Jan 28, 2012 3:42 PM by JimHess
    converting all my lightroom files to DNG
    dougie-wougie Level 1
      I have been thinking of converting all my pictures that is under Lightroom's control to DNG. Should a use the bulk convertor or something else? Will Lightroom be confused by the conversion. Do I have to resync everything? What is the process for converting everything.
      douglas
        • 1. Re: converting all my lightroom files to DNG
          JimHess Adobe Community Professional & MVP
          I think the easiest way to convert to DNG is to use that conversion feature within Lightroom. You will be given the choice of whether or not to keep your original raw files, or to replace them with the DNG files. If you choose to replace then Lightroom will automatically know where the DNG files are located. If you use the DNG converter then it will be necessary for you to manually delete your original raw files if you choose to do that. And then it will be necessary for you to import the DNG files into Lightroom.
