1 2 Previous Next 56 Replies Latest reply: Jul 27, 2012 6:30 PM by drdagwood RSS
    accdb with CF9 under Win2008 R2 64bit
    Didi Community Member
      Hi there
      I have a accdb designed with Access 2010 64bit.
      I am running CF9 under Win2008 R2 64bit.
      I have also installed http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=13255
      I have now googled and tried some dozen tricks to get this combination work:
      until now - no way!
      Does anybody succeed to to so and is there somewhere a description?
      Thanx for help - Didi
        • 1. Re: accdb with CF9 under Win2008 R2 64bit
          BKBK ACP/MVP
          1) Did you in every case add the following line to the Connection String field in the ColdFusion Administrator?
          Driver={Microsoft Access Driver (*.mdb, *.accdb)};DBQ=path_to_mdb/accdb_file
          2) Do you have any 32Bit MS Office applications installed on the server?
          • 2. Re: accdb with CF9 under Win2008 R2 64bit
            ad 1)  I try again
            I guess it must be in the form c:\mypath\myDB.accdb
            Backslashes, not forward slashes?
            ad 2) nope
            When I add a new Datasource in CFadmin, what Type of Driver do I select??
            • 3. Re: accdb with CF9 under Win2008 R2 64bit
              BKBK ACP/MVP
              Didi wrote:
              ad 1)  I try again
              Your path OK.
              MS Access
              • 4. Re: accdb with CF9 under Win2008 R2 64bit
                Clicking Submit says ..
                Unable to update the NT registry.
                Variable DRIVERPATH is undefined.
                And when I try to verify the datasource it says ..
                Connection verification failed for data source: movo2direct
                java.sql.SQLException: [Macromedia][SequeLink JDBC Driver][ODBC Socket]internal error: The specified DSN contains an architecture mismatch between the Driver and Application
                The root cause was that: java.sql.SQLException: [Macromedia][SequeLink JDBC Driver][ODBC Socket]internal error: The specified DSN contains an architecture mismatch between the Driver and Application
                • 5. Re: accdb with CF9 under Win2008 R2 64bit
                  BKBK ACP/MVP
                  Ah, I see. That is a well-known problem. Had you registered the system DSN yet?
                  In any case, let's start all over again. Delete everything from the Connection String field. The steps follow.
                  1) You'll have to start by registering the (MS Access) System DSN. To do so, double-click on the file c:\windows\SysWOW64\odbcad32.exe to launch it.
                  2) Select the tab System DSN and press Add. Select Microsoft Access Driver(*.mdb, *.accdb) and press Finish.
                  3) Give the datasource a name. (Jot it down, as it is the same datasource name you will have to use in the ColdFusion Administrator.) Now, double-click on the datasource  name (Alternatively,  press Configure.). You should now get an interface with which to add a database.
                  4) Press Select. Under the Directories: field, locate the directory in which you have stored your MDB or ACCDB file. The list of files in the directory should automatically appear in the field to the left.
                  5) Click on the database you require, and press OK. In so doing, you have coupled the database to the datasource.
                  6) Press OK, and again OK, to leave the ODBC interface.
                  7) Verify that Windows has created the right registry values. To do so, run Wndows' regedit on the command-prompt. You should have registry entries similar to the following:
                  HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ODBC\ODBC.INI\myAccessDSN\
                      DBQ=C:\Users\BKBK\Documents\myDB.accdb
                      Driver=C:\PROGRA~2\COMMON~1\MICROS~1\OFFICE14\ACEODBC.DLL
                      DriverId=dword:00000019
                      FIL=MS Access
                  HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ODBC\ODBC.INI\ODBC Data Sources\
                      myAccessDSN=Microsoft Access Driver (*.mdb, *.accdb)
                  While configuring Windows ODBC, the name I gave for my datasource was myAccessDSN. That is also the name I am giving to the datasource in the Administrator. The location of my Access database is C:\Users\BKBK\Documents\myDB.accdb. That was it then.
                  After following the above procedure, I still got the following familiar error message when I attempted to verify the datasource in the Administrator:
                  That is known to possibly be a bug. So I ignored it. I went ahead and ran a cfquery on the Access database. It worked!
                  Useful references:
                  • 6. Re: accdb with CF9 under Win2008 R2 64bit
                    There is no
                    CFadmin says
                    Well, I will go and read the articles you cited, maybee this brings me further ...
                    • 7. Re: accdb with CF9 under Win2008 R2 64bit
                      BKBK ACP/MVP
                      There is no Microsoft Access Driver(*.mdb, *.accdb)
                      You don't need to look any further. It is clear from your picture that you've only got the older versions of the drivers. Like you, I have versions 6.01.7600.17632. But I have also got versions 14.00.4760.1000, too.
                      Something must have gone wrong during your installation of the MS Access Database Engine 2010. Reinstall it.
                      If you encounter any problems installing the 64-bit version, then install the 32-bit version. Restart Windows(!) and follow the 7 steps I gave above.
                      • 8. Re: accdb with CF9 under Win2008 R2 64bit
                        I don't think, that the installation went wrong. I have done this several times yet and it never indicates any error.
                        Let me ask something else first :
                        I use myDB.accdb created  with  Access 2010 64bit. I would now guess, that the *.accdb is also 64bit - is that correct?
                        How can I verify that?
                        And further, that I need 64bit drivers?
                        As much as I understand from the articles you cited, "c:\windows\SysWOW64\odbcad32.exe" is meant for using 32bit drivers on a 64bit windows.
                        What we see are Version 6 drivers which I think are 32bit drivers. This seems consistet to the above.
                        So how could this work?
                        • 9. Re: accdb with CF9 under Win2008 R2 64bit
                          BKBK ACP/MVP
                          From what you've said, we don't need to check. Your installation went smoothly. So, if you installed 64-bit, then you have 64-bit.
                          However, I am now of the opinion that, what you need in order to run Access, are the 32-bit drivers! Yes, the 32-bit, not the 64-bit, drivers! I would even wonder aloud: 64-bit MS Access 2010 may sometimes require only 32-bit drivers, for example, on an Operating System running certain Microsoft 32-bit applications like Office(and certain applications like ColdFusion). Notice how Microsoft themselves put the 32-bit binary odbcad32.exe in the 64-bit directory c:\windows\SysWOW64\. This means it also applies to 64-bit!
                          Of course, the gist of this all is that 32-bit software may run on a 64-bit Operating System like your Win2008. So, the Microsoft Access Driver (*.mdb, *.accdb) on my 64-bit Windows 7 must have come from my 32-bit installation of the MS Access Database Engine 2010.
                          A test worth doing is to uninstall the 64-bit Access 2010 engine, and install the 32-bit version. You cannot have both versions on the same machine.
                          • 10. Re: accdb with CF9 under Win2008 R2 64bit
                            Following the links you referenced I found the following information:
                            http://www.coldfusionmuse.com/index.cfm/2010/12/31/Access.on.64bit.ColdFusion
                            Here's the catch. Windows 64bit is capable of running 32bit software. You know this if you think about it. In fact the odbcad32.exe file above is a 32 bit control panel applet for managing 64 bit drivers. So the trick is to figure out how to manage 32bit drivers on your system. The good news is that the old version of the ODBC manager (the one that handles 32 bit drivers) still exists on your 64bit machine. Take a look in the %systemroot%/sysWOW64/ folder. You will see a version of the same file - odbcad32.exe. Open this control panel applet and you will discover that it actually manages the old list of 32 bit drivers. I know it's convoluted - a file in "system32" called odbcad32.exe manages 64 bit drivers while a file in the sysWOW64 folder manages 32 bit drivers. If you need to know, the "sysWOW64" folder stands for "Windows on Windows 64" - meaning plain old Windows 32 bit aps running on the Windows 64 bit platform.
                            This goes consistent with my following observation:
                            so the Version 14 Drivers, which I assume are the newly installed 64bit drivers, show up in System32 :-)
                            Now one could think to be on the enlighted path ... nope!
                            Connecting CF9 to a such created System DNS says :
                            Life ain't easy  ...
                            Well, looking on a solution before I stumbled over this forum I have everywhere found the information, that *.accdb created with  DO NEED 64bit drivers.
                            That's why I installed AccessDatabaseEngine_x64.exe.
                            Question: How can I find out, whether my .accdb is 32bit  or 64bit ???
                            • 11. Re: accdb with CF9 under Win2008 R2 64bit
                              BKBK ACP/MVP
                              Indeed. That was also what I observed.
                              I don't find it convoluted at all. I, too, came across the meaning of WOW64. In fact, I am surprised that, having discovered what it stands for, you still went ahead and used the binary odbcad32.exe in System32 rather than the version in SysWOW64! That is why you got this error: "The specified DSN contains an architecture mismatch between the Driver and Application".
                              In any case, that error message also tells me that your ACCDB file may be 64-bit. Again, for the purposes of creating Microsoft Access DSN in ColdFusion, you will need to create a 32-bit System DSN using this 32-bit application: c:\windows\SysWOW64\odbacd32.exe.
                              • 12. Re: accdb with CF9 under Win2008 R2 64bit
                                Let me explain why I hesitate to deinstall AccessDatabaseEngine_x64.exe and install the 32-Engine:
                                Actually I have found a way to get to the data in my *.accdb by linking it to SQLServer 2008 R2 Express.
                                This works if AccessDatabaseEngine_x64.exe is installed, since nly then it finds the following Provider
                                However, for several reasons I do not like this approach.
                                Rather I would like a 'direct' mounting as we discussed it above.
                                Of course I fear to loose my linked db when I deinstall AccessDatabaseEngine_x64.exe :-(
                                One (more) thing  I do not understand:
                                In SQL Express it says version 12.0 whereas in the system32\adbcad32.exe it says 14.0
                                Why is this?
                                Which version is the one that works with you?
                                Mystery over mystery ...
                                • 13. Re: accdb with CF9 under Win2008 R2 64bit
                                  BKBK ACP/MVP
                                  12 and 14 are the names that Microsoft's developers gave under the hood for, respectively, Office 2007 and Office 2010. So, where you see version 12.0, Microsoft Office 2007 Access is being implied. Where you see version 14.0, Microsoft Office 2010 Access is being implied. You appear to have both Access versions installed. Could it be that you are mixing up the version 12.0 driver with the version 14.0 Access?
                                  Besides Office version, the other main consideration is Bitness. On 64 bit Windows, such as yours, 64 bit applications are stored in Program Files (Progra~1, for short), and 32 bit applications are stored in Program Files (x86) (Progra~2, for short). Furthermore, the Windows system directory for 32-bit files is C:\Windows\SysWOW64, and the Windows system directory for 64 bit files is C:\Windows\System32.
                                  64 bit Windows can handle 32 bit as well as 64 bit versions of an application. However, it's all down to how you put your configuration together.
                                  The driver for Access has the same name in Office 2007(v. 12.0) and in Office 2010 (v. 14.0), which is, ACEODBC.DLL. The location of that driver will be as follows, depending on whether the Office version is 32 bit or 64 bit:
                                  32 bit Office 2007: C:\PROGRA~2\COMMON~1\MICROS~1\OFFICE12\ACEODBC.DLL
                                  64 bit Office 2007: C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE12\ACEODBC.DLL
                                  32 bit Office 2010: C:\PROGRA~2\COMMON~1\MICROS~1\OFFICE14\ACEODBC.DLL
                                  64 bit Office 2010: C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE14\ACEODBC.DLL
                                  I'll illustrate using my own case. I have 32-bit Microsoft Office 10. The Access driver my system uses is therefore C:\PROGRA~2\COMMON~1\MICROS~1\OFFICE14\ACEODBC.DLL. Scroll up to the 7 steps I gave above. You will see that that is indeed the value of the driver in my Windows registry. You, too, should verify your registry entries.
                                  How did I configure the Access System DSN? By following the 7 steps above. My Office version is 32-bit, so I used C:\Windows\SysWOW64\odbcad.exe. If your Office version is 64 bit, then you should use C:\Windows\System32\odbcad.exe instead.
                                  • 14. Re: accdb with CF9 under Win2008 R2 64bit
                                    ok, I finally did it!
                                    Fortunately, my server is running as a VM on ESX. So I took a snapshot, deinstalled the AccessDatabaseEngine_x64.exe and installed AccessDatabaseEngine.exe.
                                    Then I configured in SysWOW64\odbacd32.exe a DSN with the v14.0 Provider.
                                    I think this is exactly what you meant by .. ?
                                    Next: In CFadmin I added two datasources: one via odbc (movo2odbc), one directly with acces (movo2accdb):
                                    Well, my data-coffin says:
                                    Do you have this running under the same configuration ( CF9 under Win2008 R2 64bit ) ?
                                    hi, we just crossed posting .. this one is done without reading the previous one. I will do so instantly ..
                                    • 15. Re: accdb with CF9 under Win2008 R2 64bit
                                      ok, once again with
                                      • 16. Re: accdb with CF9 under Win2008 R2 64bit
                                        Hi there
                                        first of all: thousand thanx of taking care of my problem !!!
                                        Most things you say  I understand, but some still confuses me.
                                        ok, on my server, no MSO is installed at all. The my.accdb is created on a Win7 64 bit  with MSO 2010 64bit - no doubt about that!
                                        Then I copied it to the server (Win2008 R2 64bit)
                                        some puzzles remain ..
                                        Since my MSO is 64 I tried now (having installed AccessDatabaseEngine.exe ) C:\Windows\System32\odbcad.exe
                                        Hmmmm ...where are the drivers?
                                        C:\Windows\SysWOW64\odbcad.exe on the other hand says ..
                                        one more thing:
                                        As you can see from earlier Screenshots: when neither AccessDatabaseEngine_x64.exe nor AccessDatabaseEngine.exe is installed,
                                        I don't see either the v12-Provider in SQL server nor the v14-Driver in odbacd32.exe.
                                        So it's AccessDatabaseEngine_x64.exe who introduces both drivers at setup.
                                        • 17. Re: accdb with CF9 under Win2008 R2 64bit
                                          One more question:
                                          I have a 64-bit Office with which I create a my.accdb, then I copy it to a 64bit server.
                                          Why do I need to install AccessDatabaseEngine.exe and not AccessDatabaseEngine_x64.exe ?
                                          That's absolutely confusing to me ....
                                          • 18. Re: accdb with CF9 under Win2008 R2 64bit
                                            BKBK ACP/MVP
                                            I would assume that Windows installs Microsoft Access 2010 as a Microsoft Office 2010 application. OK, yours is 64 bit. Did you install the 64 bit AccessDatabaseEngine_x64.exe on Win2008? My guess is that you should
                                            A mistake. AccessDatabaseEngine.exe is 32 bit, and so you require C:\Windows\SysWOW64\odbcad.exe for it.
                                            You don't need to. To keep everything to 64 bit, you should install AccessDatabaseEngine_x64.exe! However, as I said before, it's all about 2 things: driver version and bitness. If you wish to run  applications that require 32-bit Access drivers, you should install AccessDatabaseEngine.exe instead.
                                            • 19. Re: accdb with CF9 under Win2008 R2 64bit
                                              Well, lucky boy who has a snapshot :-)
                                              Now I am back at the point where I entered this thread, but now with a more precise description of what I am doing:
                                              1. I have a 64-bit Office on a Win 7 64bit Workstation, with which I create a my.accdb.
                                              2. Then I copy it to a server running CF9 under Win2008 R2 64bit..
                                              3. I have installed AccessDatabaseEngine_x64.exe
                                              4. I use  C:\Windows\System32\odbcad.exe
                                              5. Creating a DSN it offers me v14.0 drivers
                                              6. Adding a new Datasource in CFadmin says:
                                              But at least we seem now to agree, that both of us assume that I am doing the right thing? Don't we?
                                              Or do I still miss something?
                                              • 20. Re: accdb with CF9 under Win2008 R2 64bit
                                                Owain North Community Member
                                                Are you sure you *really* want to go through all this just to use Access...?
                                                • 21. Re: accdb with CF9 under Win2008 R2 64bit
                                                  BKBK ACP/MVP
                                                  I missed 2 things. You mentioned nothing about uninstalling the 32 bit engine nor about the registry.
                                                  Uninstall AccessDatabaseEngine.exe. Restart Win2008. (Re)Install AccessDatabaseEngine_x64.exe.
                                                  Corresponding to the above, the 7 steps for 64 bit Microsoft Access 2010 are:
                                                  1) You'll have to start by registering the (MS Access) System DSN. To do so, double-click on the file c:\windows\System32\odbcad32.exe to launch it.
                                                  5) Click on the MDB or ACCDB database you require, and press OK. In so doing, you have coupled the database to the datasource.
                                                  HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\myAccessDSN\
                                                      Driver=C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE14\ACEODBC.DLL
                                                      FIL=MS Access
                                                  HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\ODBC Data Sources\
                                                  In this configuration, myAccessDSN is the name I give for my datasource. You should see your own instead. MyAccessDSN is also the name I would give to the datasource in the Administrator. The location of my Access database is C:\Users\BKBK\Documents\myDB.accdb. That was it then.
                                                  • 22. Re: accdb with CF9 under Win2008 R2 64bit
                                                    There is not need to uninstall AccessDatabaseEngine.exe since I reverted my ESX VM back to a snapshot with my original setup ( CF9 under Win2008 R2 64bit plus AccessDatabaseEngine_x64.exe )
                                                        FIL=MS Access
                                                    Exactly what I have done - step by step ..
                                                    • 23. Re: accdb with CF9 under Win2008 R2 64bit
                                                      BKBK ACP/MVP
                                                      You and I have gone as far as we can. My conclusion is that, when you install an MS Access datasource in the ColdFusion Administrator, ColdFusion uses a 32-bit application, macromedia.jdbc.MacromediaDriver, in the process.
                                                      To see this, run the following code (using your own admin password):
                                                      <cfset adminLogin=createobject("component","CFIDE.adminapi.administrator").login("my_cf_admin_pw ")>
                                                      <cfset ds=createobject("component","CFIDE.adminapi.datasource")>
                                                      <cfdump var="#ds.setMSAccess#" >
                                                      This shows that the driver class is macromedia.jdbc.MacromediaDriver. In fact, the following code will let you see even further.
                                                      <cfset macromediaDriver=createobject("java","macromedia.jdbc.MacromediaDriver")>
                                                      <cfdump var="#macromediaDriver#" >
                                                      Macromedia.jdbc.MacromediaDriver is actually a legacy engine for setting the appropriate driver for a collection of databases, namely for DB2, Informix, MySQL, and so on. One of them, SequeLink, is for MS Access. I do believe that this construction is 32-bit, hence the incompatibility.
                                                      • 24. Re: accdb with CF9 under Win2008 R2 64bit
                                                        <cfset adminLogin=createobject("component","CFIDE.adminapi.administrator").l ogin("my_cf_admin_pw")>
                                                        <cfset macromediaDriver=createobject("java","macromedia.jdbc.MacromediaDrive r")>
                                                        This means no chance?
                                                        Another idea:
                                                        Would you give a chance to something like that?
                                                        url="jdbc:odbc:MyAccessDB"
                                                        className="sun.jdbc.odbc.JdbcOdbcDriver"
                                                        I did not find any information yet, whether 64bit is supported.
                                                        I used something like that many years ago, at that time it was for sur not 64bit.
                                                        Or maybe even better something like that:
                                                        "jdbc:odbc:DRIVER=Microsoft Access Driver (*.mdb, *.accdb);DBQ=C:\\Northwind.accdb;PWD=1L0v3Acce55;"
                                                        Does this make sense? And how do I teach CF9 to use the correct driver?
                                                        (Ref:   http://msdn.microsoft.com/en-us/library/ff965871.aspx#DataProgrammingWithAccess2010_JDBCOD BCExample )
                                                        • 25. Re: accdb with CF9 under Win2008 R2 64bit
                                                          BKBK ACP/MVP
                                                          That would in fact be my suggestion now: download and install an appropriate legacy 64 bit JDBC-ODBC driver.
                                                          • 26. Re: accdb with CF9 under Win2008 R2 64bit
                                                            BKBK wrote:
                                                            That would in fact be my suggestion now: download and install an appropriate legacy 64 bit JDBC-ODBC driver SQL Server Express.
                                                            • 27. Re: accdb with CF9 under Win2008 R2 64bit
                                                              BKBK ACP/MVP
                                                              Owain North wrote:
                                                              Point taken. However, mine is not to wonder why Access.
                                                              • 28. Re: accdb with CF9 under Win2008 R2 64bit
        Hi BKBK
        thanx again a thousand times for spending competence and patience !!!
        @Owain: I definitely agree - if starting on greenfield. Unfortunatly, we sometimes have to live with legacy.
        • 29. Re: accdb with CF9 under Win2008 R2 64bit
        Completely agree it's not always so easy, and I'm sure no developer would ever be the one to choose Access. Take this thread as an example though - how many hours have you burned trying to get it to work? It's Access 2010, so someone somewhere is still actively upgrading your Access database, presumably still thinking it's the right thing to do.
        I appreciate it's not always easy, but Access is not made for web applications. It never will be, and every time you come to change/upgrade you'll go through this much pain and then some.
        If you can, I'd look at moving away from it before you find support is pulled completely
        • 30. Re: accdb with CF9 under Win2008 R2 64bit
        BKBK ACP/MVP
        Didi,
        Before I go JDBC, just one last stab with 64 bit, for the purpose of elimination. Set the DSN up in the Administrator, choosing "Microsoft Access" as driver.
        For the "Database File", browse to and select your (64 bit) ACCDB file. Next, click on "Show Advanced Settings". Enter the following as "Connection String":
        jdbc:odbc:Driver={Microsoft Access Driver (*.mdb,*.accdb)};DBQ=absolute_path_to_accdb_file
        Click to "Submit" the changes. What is the result?
        • 31. Re: accdb with CF9 under Win2008 R2 64bit
        BKBK wrote:
        Didi,
        I guess I have done that before and it did not work - but I'll try it again (we NEVER give up ;-)
        • 32. Re: accdb with CF9 under Win2008 R2 64bit
        I tried
        • jdbc:odbc:Driver={Microsoft Access Driver (*.mdb,*.accdb)};DBQ=Z:\DATABASE\Didi\2010-64.accdb    OR
        • jdbc:odbc:Driver={Microsoft Access Driver (*.mdb,*.accdb)};DBQ=Z:\DATABASE\Didi\2010-64.accdb;   OR
        • jdbc:odbc:Driver=Microsoft Access Driver (*.mdb,*.accdb);DBQ=Z:\DATABASE\Didi\2010-64.accdb
        as well as
        • Database File = Z:\DATABASE\Didi\2010-64.accdb   AND/OR
        • System Database File = Z:\DATABASE\Didi\2010-64.accdb
        Same result:
        When registering:
        When verifying:
        Connection verification failed for data source: movo2accdb
        • 33. Re: accdb with CF9 under Win2008 R2 64bit
        BKBK ACP/MVP
        Didi wrote:
        I tried
        as well as
        Same result:
        When registering:
        When verifying:
        Sufficient:
        Register. No need to verify. Now, run a ColdFusion CFM page containing the following code:
        <cfquery name="testQ" datasource="movo2accdb">
        select *
        from your_table_name
        </cfquery>
        <cfdump var="#testQ#">
        If this test succeeds, then your 64-bit installation will have worked. The error would have been caused by ColdFusion engaging the (my guess) 32-bit Macromedia driver and by the NT/DRIVERPATH issue which many consider a longstanding bug.
        • 34. Re: accdb with CF9 under Win2008 R2 64bit
        Sorry I did not mention that:
        of course I always do the 'practical' test as you proposed.
        It gives me an error with a coherent comment:
        • 35. Re: accdb with CF9 under Win2008 R2 64bit
        BKBK ACP/MVP
        OK. That was that then. Let's move on.
        I do believe our hopes now lie with JDBC. Since ColdFusion is a Java application, finding a 32-bit and 64-bit JDBC driver for MS Access will help many developers.
        My search brought me to HXTT's JDBC driver for MS Access. The only problem is, I couldn't tell whether their driver is for 32-bit or 64-bit Access. Could it (hopefully) be universal, automatically detecting the system?
        (After the customary virus scan) I unpacked their access.zip file, copied the essential file Access_JDBC40.JAR from /access/lib/ to ColdFusion's lib directory. That's all there is to installing the driver. I then restarted ColdFusion.
        I went to the ColdFusion Administrator and configured a datasource as follows:
        Data Source Name: myAccessDSN
        Driver: Other
        JDBC URL: jdbc:access:/C:/Users/BKBK/Documents/myDB.accdb
        Driver Class: com.hxtt.sql.access.AccessDriver
        Driver Name: com.hxtt.sql.access.AccessDriver
        It worked flawlessly. But then again, though I installed everything you did, I am on 32-bit Access.
        • 36. Re: accdb with CF9 under Win2008 R2 64bit
        Hi BKBK
        Thanx! For the moment I am not able to try it on my system - but I will do ASAP :-)
        • 37. Re: accdb with CF9 under Win2008 R2 64bit
        Hi BKBK (as of now Sorcerer Of ColdFusion)
        Does this take any more words ???
        10^9 thanx to you!
        -Didi
        • 38. Re: accdb with CF9 under Win2008 R2 64bit
        BKBK ACP/MVP
        Thanks to you, too, Didi, for offering me this opportunity to learn.
        • 39. Re: accdb with CF9 under Win2008 R2 64bit
        hi there
        I would follow up on this thread since it perfectly documents the background.
        Let's summarize: with http://www.hxtt.com/access.html and BKBK's support we now have a working environment.
        One thing puzzles us:
        The following steps work fine:
        1. SELECT qry from CF9 to the  DS
        2. UPDATE DS from CF9
        3. SELECT qry from CF9 to the DS (this reflects the change made in the step before)
        But this procedure does not work
        2. UPDATE the underlying table from within MS Access
        3. SELECT qry from CF9 to the  DS (this does NOT reflect the change made in the step before)
        What we already tried:
        • CFOBJECTCACHE does not help.
        • Setting "" in CFadmin does not help.
        • Disabling "Maintain Connections" in the Datasource does not help (see below).
        Anybody a helpful idea?  (A recommendation to change the database is NOT regarded as helpful )
        -Didi
        1 2 Previous Next
