Problem with Create PDF for Review command
Jan 30, 2012 Jan 30, 2012
When creating a PDF using Review > Create PDF for Review, RoboHelp produces a PDF with what seems to be "stub" text, similar to Greeked text.CreatPDFforReview.gif
We have RoboHelp 9.0.2, Windows 7, 64 bit, and Tortoise CVS 1.10.9 for source control. At first I suspected CVS was the problem, so I copied the project to a new, non-source controlled local drive. (CVS is installed locally). Same result.
I opened one of the sample projects and created the PDF with no problems. So I tried creating a new blank project using one of the template projects, Application Help. I got the same greeked text again.
Has anyone encountered this problem?
Jan Shelton
900
Jan 31, 2012 Jan 31, 2012
Not a problem I have seen reported.
If you want to send me the new project to test, I will see what I get.
See the Contact page on my site and use one of the sites suggested there or your own preferred service. Include a link to this thread in the covering note they will send.
@petergrainge
Works fine here. What version of Acrobat are you using?
@petergrainge
Acrobat X Pro
We just installed Technical Communication Suite 3.5.
We can rule out:
  • The wrong version or PDF creator - You have the suite
  • Your project - That works fine here.
  • Your installation of TCS as it works with the supplied samples.
Is this demo project on your local drive and are you creating the PDF Review in a local folder?
@petergrainge
Thank you Peter. As I should have before I posted, I had my manager try it - she got the same results you did. So something is awry with my installation of Acrobat I should think. It works fine with the supplied examples because my version of Acrobat did not generate them.
Can my IT department install only Acrobat or do they have to reinstall the entire suite?
I believe the setup of TCS allows you to install and uninstall separate components but not do a repair. So they could try uninstalling just Acrobat and then reinstalling.
If that fails then you could suggest to IT that they try uninstalling the whole suite using RevoUninstaller. It removes more of the registry entries that programs leave behind and it has given good results. There call and responsibility though!
@petergrainge
Thanks again for your expertise. I will post the results.
RoboHelp Documentation
Download Adobe RoboHelp
