I am not able to configure email endpoint with SMTP and IMAP server. When i deploy the process, it shows me error that "could not connect". What could be the reason.
Using send email activit, i am able to configure SMTP for sending emails. But not able to configure and deploy email endpoint.
Please provide help
Sunil Gupta
Solved! Go to Solution.
Total Likes
Thanks Nith
for providing consitent help on this forum..
I was able to configure the email exchange server. Earlier the problem was with the firewall. We had more than one firewall layers and one of the firewall out of three was blocking it. so infrastructure team helped us to resolve the issue..
thanks
Regards
Sunil Gupta
Total Likes
Find out the protocol and port used to receive emails from your email server.
Default values are given below (for MS Exchange Server):
SMTP - 25 (Only for Sending Emails)
POP3 - 110
IMAP - 143
POP3s - 995 (SSL)
IMAPs - 993 (SSL)
You can verify connectivity by using TELNET command from a command prompt
syntax: telnet email_server_host PORT
e.g. telnet myserver.exchange.com 110
If you succeed with the above command, you can use the same values to configure email endpoint.
Nith
Thanks Nith
thanks
Regards
Sunil Gupta
Total Likes
