1. Re: How to communicate between AEGPs?
shachar carmi Jan 31, 2012 10:43 PM (in response to dheeraj_c)yes, a custom suite is the way to go.
just wait with using the suite after you're sure al the AEGPs have loaded, otherwise you might try to use the suite before it has been defined.
you didn't have that problem with using a suite in an effect because AE loads AEGPs first, and only then the effects.
the first idle call would be a good time to load the suite.
2. Re: How to communicate between AEGPs?
dheeraj_c Feb 1, 2012 1:26 AM (in response to shachar carmi)Thanks a lot for sharing the info shachar
3. Re: How to communicate between AEGPs?
SirPentor75 Feb 1, 2012 9:28 AM (in response to dheeraj_c)This sounds interesting. What's a good keyword to look for in the after effects sdk doc for information on a custum suite? Thanks!
4. Re: How to communicate between AEGPs?
shachar carmi Feb 1, 2012 9:38 AM (in response to SirPentor75)well, it's not really documented...
the documentation only refers you to the relevant samples.
so,
look at the "sweetie" sample to see how to create the custom suite,
and at the "checkout" sample (in the globalSetup() function) to see how to
use the custom made suite.
but are you sure a custom suite is what you need?
you only need a custom suite to enable an effect or AEGP to contact another
AEGP. (for whatever reason)
5. Re: How to communicate between AEGPs?
SirPentor75 Feb 1, 2012 1:35 PM (in response to shachar carmi)Thanks. In this case I really doubt I would need to use one, but it sounded like an interesting concept worthy of investigating.
6. Re: How to communicate between AEGPs?
shachar carmi Feb 1, 2012 11:50 PM (in response to SirPentor75)investigate away.
(it is a powerful tool for many cases)
