Extending App.cfc and file paths
Feb 01, 2012 Feb 01, 2012
I have a setup where I grab the root path of my application in app.cfc using GetDirectoryFromPath(GetCurrentTemplatePath()) and set it in the application scope through OnApplicationStart. This works great for most of the site, but I have one subfolder where I've extended app.cfc to add a login script to OnRequestStart.  The problem I'm having is if the application starts up from that subfolder, the extended app.cfc sets the root path from the subfolder instead of the root folder where the original app.cfc is located.
Anyone know a way to fix this?
Advanced techniques
600
Feb 04, 2012 Feb 04, 2012
I do believe that that is the expected behaviour. ColdFusion invokes the system functions relative to the caller.
That, in fact, also suggests a possible solution. Create the following component in the same directory as the parent Application file.
Path.cfc
<cfcomponent output="no">
    <cffunction name="getPath" output="no" returntype="string">
        <cfreturn GetDirectoryFromPath(GetCurrentTemplatePath())>
    </cffunction>
</cfcomponent>
Then modify the code in the parent Application.cfc to call the functions relative to the Path object, like this
<cfcomponent>
    <cffunction name="onApplicationStart" returntype="boolean">
        <cfset application.path = createobject("component","Path").getPath()>
        <cfreturn true>
     </cffunction>
</cfcomponent>
Feb 11, 2012 Feb 11, 2012
Another idea: hard-code it in onApplicationStart as an application constant, for example
<cfset application.path = "c:\ColdFusion9\wwwroot\mySite\myDir\index.cfm">
Documentation
