I am trying to create an iOS app that loads my companies product catalogue into a webview stage. I cannot figure out after a lot of google how to access this local file, although external files load fine. I'm trying to use the "file:" command. I'm doing this in flash builder.
<![CDATA[
import flash.display.MovieClip;
import flash.media.StageWebView;
import flash.geom.Rectangle;
var webView:StageWebView = new StageWebView();
var yOffset = 47
public function FestoKP() {
webView.stage = this.stage;
webView.viewPort = new Rectangle( 0, yOffset, stage.stageWidth, stage.stageHeight - yOffset);
webView.loadURL( "file:///asset/Festo_KP_Catalogue.pdf" );
closeBtn.visible = true
public function Close() {
webView.stage = null;
closeBtn.visible = false;
I am on the same boat. Did you ever find a good working example? -I'm about to give up.
Yes, I actually did finally figure it out. I ended up scraping this method though because although it works very well in iOS, it does not work on android. Would you still like me to post the code? I ended up completing this project in Xcode instead, so it'll take a bit to dig up.
These guys at "CultCreative" seem to have the ideal solution for FB (it even checks to see if a newer .pdf is on a server) but my project was built in Flash Pro CS5.5 so again just want to load a few local .pdf files which would be bundled up with the app.
http://www.cultcreative.com/tutorials/11/13/2011/local-file-access-editing-for-android-and-ios/
I'm still interested in the method you used for iOS if it works well with Air (3.1) for iOS. However, I am determined to find a way of using Flash Pro CS5.5 to do so. Thanks! -if you can find it, and think your AS3 from FB would work for me.
In the example below, I included a close button to close the webview. This function is at the bottom. Y-offset is the height of the toolbar at the top.
<fx:Script>
<![CDATA[
var yOffset = 45;
var yTabs = 54;
//var yOffset = 90;
//var yTabs = 107;
private function loadDSPF():void {
webView.viewPort = new Rectangle( 0, yOffset, stage.stageWidth, stage.stageHeight - yOffset );
var fileName:String = "foldername/filename";
var sourceFile = File.applicationDirectory.resolvePath( fileName );
var workingFile = File.createTempFile();
try
sourceFile.copyTo( workingFile, true );
// You have to rename the temp file
var renamedTempFile:File = workingFile.resolvePath(workingFile.nativePath + fileName);
workingFile.moveTo(renamedTempFile, true);
webView.loadURL( renamedTempFile.url );
closeBtn.visible = true;
catch (err:Error) { }
allBtn.enabled = true;
</fx:Script>
hope that helps. I can explain anything else if you need.
This was perfect thanks!
