0 Replies Latest reply on Feb 2, 2012 5:52 AM by Jim MacD
    New to Dialog Boxes and I'm stuck
    Jim MacD
      Seems there is no way to format a field in a Dialog Box. How can a field be checked to determine if the correct type of data was entered in it, when the user moves to the next field, before data is committed?
      I am stuck on how to limit the number of characters entered into the postal code and phone fields. I want to limit the number of numeric characters that can be entered in each phonenumber field ie  3 numbers, 3numbers and 4 numbers (999 999 9999)  And postal code field ie 3 characters and 3 characters (A9A 9A9)
      Also, once the user enters the required number of characters in the phone and postal code fields, the code should tab to the next field. And yes, I read about tab_first and next_tab, but don't understand how it works. The way I see it working is that once a phone or postal code field is filled with the required number of characters, control automatically tabs to the next field.
      I am using Adobe Acrobat Professional 8
      This code was written by trail and error using examples from various sources ie Acrobat JavaScript Scripting reference - version 7.0.5, Acrobat JavaScript Scripting Guide - version 7.0, and I have very little experience in creating a dialog box and its code - forgive the mess.
      var goon=true;
      var result;
      var address;
      var city;
      var province;
      var sign;
      var postalcodea;
      var postalcodeb;
      var homephone;
      var homephoneareacode;
      var homephoneprefix;
      var homephonenumber;
      var businessphone;
      var businessphoneareacode;
      var businessphoneprefix;
      var businessphonenumber;
      address = this.getField("Text1-2-Address").value;
      city = this.getField("Text1-2-City").value;
      var provincelist = new Array();
      provincelist[1] = " ";
      provincelist[2] = "Alberta";
      provincelist[3] = "British Columbia";
      provincelist[4] = "Manitoba";
      provincelist[5] = "New Brunswick";
      provincelist[6] = "Newfoundland & Labrador";
      provincelist[7] = "Northwest Territories";
      provincelist[8] = "Nova Scotia";
      provincelist[9] = "Nunavut";
      provincelist[10] = "Ontario";
      provincelist[11] = "Prince Edward Island";
      provincelist[12] = "Québec";
      provincelist[13] = "Saskatchewan";
      provincelist[14] = "Yukon";
      var sign = new Array();
      for (var i=0; i<15; i++)
                  sign[i] = "-";
                  if(provincelist[i] == this.getField("Client's Full Province Name").value)
                              sign[i] = "+";
      postalcodea = "";
      postalcodeb = "";
      if(this.getField("Text1-2-Postal-Code").value != "")
                  postalcodea = this.getField("Text1-2-Postal-Code").value;
                  postalcodea = util.printx("A9A", postalcodea);
                  postalcodeb = this.getField("Text1-2-Postal-Code").value;
                  postalcodeb = postalcodeb[4]  + postalcodeb[5] + postalcodeb[6];
      homephoneareacode = "";
      homephoneprefix = "";
      homephonenumber = "";
      if(this.getField("Text1-2-Home-Phone-Number").value != "")
                  homephone = util.printx("9999999999", this.getField("Text1-2-Home-Phone-Number").value);
                  homephoneareacode = homephone[0] + homephone[1] + homephone[2];
                  homephoneprefix = homephone[3] + homephone[4] + homephone[5];
                  homephonenumber = homephone[6] + homephone[7] + homephone[8] + homephone[9];
      businessphoneareacode = "";
      businessphoneprefix = "";
      businessphonenumber = "";
      if(this.getField("Text1-2-Business-Phone-Number").value != "")
                  businessphone = util.printx("9999999999", this.getField("Text1-2-Business-Phone-Number").value);
                  businessphoneareacode = businessphone[0] + businessphone[1] + businessphone[2];
                  businessphoneprefix = businessphone[3] + businessphone[4] + businessphone[5];
                  businessphonenumber = businessphone[6] + businessphone[7] + businessphone[8] + businessphone[9];
      var dialog2 =
                  initialize: function(dialog)
                               dialog.load(
                                                       stat:     "Client Address and Phone Information is required in forms you are about to link to. To save time, enter Address and Phone Information before linking to these documents.",
                                                      str1: address,
                                                      str2: city,
                                                      stra: postalcodea,
                                                      strb: postalcodeb,
                                                      str5: homephoneareacode,
                                                      str6: homephoneprefix,
                                                      str7: homephonenumber,
                                                      str8: businessphoneareacode,
                                                      str9: businessphoneprefix,
                                                      sts1: businessphonenumber,
                                                      str3:
        "  ": (sign[1] + "1"),
        "Alberta": (sign[2] + "2"),
        "British Columbia": (sign[3] + "3"),
        "Manitoba": (sign[4] + "4"),
        "New Brunswick": (sign[5] + "5"),
        "Newfoundland & Labrador": (sign[6] + "6"),
        "Northwest Territories": (sign[7] + "7"),
        "Nova Scotia": (sign[8] + "8"),
        "Nunavut": (sign[9] + "9"),
        "Ontario": (sign[10] + "10"),
        "Prince Edward Island": (sign[11] + "11"),
        "Québec": (sign[12] + "12"),
        "Saskatchewan": (sign[13] + "13"),
        "Yukon": (sign[14] + "14"),
                  cancel: function(dialog)
                              return;
                  destroy: function(dialog)
                              return;
                  commit:function (dialog)
                              results = dialog.store();
                              var elements = dialog.store() ["str3"]
                              province = "";
                              for(var i in elements)
                                          if(elements[i]  > 0)
                                                      province = i;
                              return;
                              description:
                              name: "Address and Phone Information",
                              //align_children: "align_left",
                              //type: "static_text",
                              //char_height: 9,
                              //width: 350,
                              //height: 75,
                              elements:
                                                      type: "cluster",
                                                      elements:
        align_children: "align_top",
        alignment: "align_fill",
        type: "view",
        width: 254,
        elements:
        bold: true,
        font: "default",
        char_height: 9,
        italic: true,
        item_id: "stat",
        multiline: false,
        width: 150,
        height: 50,
        type: "view",
        align_children: "align_distribute",
        elements:
        item_id: "str1",
        type: "edit_text",
        alignment: "align_left",
        char_width: 60,
        height: 20,
        type: "view",
        elements:
        name: "       City: "
        item_id: "str2",
        type: "edit_text",
        char_width: 16,
        height: 20,
        item_id: "str3",
        type: "popup",
        char_width: 16,
        name: "Postal Code: "
        item_id: "stra",
        type: "edit_text",
        char_width: 3,
        height: 20,
        item_id: "strb",
        type: "edit_text",
        char_width: 3,
        height: 20,
        type: "view",
        elements:
        name: "Home Phone Number: ("
        item_id: "str5",
        type: "edit_text",
        char_width: 3,
        height: 20,
        next_tab: 3,
        item_id: "str6",
        type: "edit_text",
        char_width: 3,
        height: 20,
        item_id: "str7",
        type: "edit_text",
        char_width: 4,
        height: 20,
        name: "Business Phone Number: ("
        item_id: "str8",
        type: "edit_text",
        char_width: 3,
        height: 20,
        item_id: "str9",
        type: "edit_text",
        char_width: 3,
        height: 20,
        item_id: "sts1",
        type: "edit_text",
        char_width: 4,
        height: 20,
                                                      alignment: "align_center",
                                                      type: "ok_cancel",
                                                      ok_name: "Continue",
                                                      cancel_name: "Cancel"
      var dialog3 =
                  initialize: function (dialog)
                              goon=false;
                              return;
                              return;
      while (goon)
                  result = app.execDialog(dialog2);
                  if (result=="cancel")
                              goon=false;
                  if (result=="ok")
                              this.getField("Text1-2-Address").value = results["str1"];
                              this.getField("Text1-2-City").value = results["str2"];
                              this.getField("Client's Full Province Name").value = province;
                              this.getField("Text1-2-Postal-Code").value = results["stra"] + " " + results["strb"];
                              this.getField("Text1-2-Home-Phone-Number").value = results["str5"] + results["str6"] + results["str7"];
                              this.getField("Text1-2-Business-Phone-Number").value = results["str8"] + results["str9"] + results["sts1"];
                              goon=false;
