4 Replies Latest reply on Feb 3, 2012 8:44 AM by Manan Joshi
    How to get notified when InDesign Application hides (Mac)
    rafx79
      Hi!
      I need to modify the behavior of a secondary process  I launch in my plugin when the InDesign app hides (from the dock or using the cmd+h key combination).
      I was trying to add an observer and callback using the Notification Center (local) though I can't find a way to get the main or key window to do so.
      Anyone has any pointers as how I can do this?
        • 1. Re: How to get notified when InDesign Application hides (Mac)
          Dirk Becker Level 4
          I'm not sure what you mean with Notification Center (local).
          Sounds like an OSX specific thing.
          Instead, attach an InDesign IObserver to the kAppBoss, protocol IID_IAPPLICATION.
          You'll receive kApplicationSuspendMsg and kApplicationResumeMsg.
          Hth,
          Dirk
          • 2. Re: How to get notified when InDesign Application hides (Mac)
            rafx79 Level 1
            I only receive the kApplicationSuspendMsg (InDesign CS3), what could I be missing?
            In the startupshutdown i have:
            obsv = (IObserver*) CreateObject (kAppObserverBoss, IID_IOBSERVER);
            //attach app messages observer
            InterfacePtr<IApplication> iApp (gSession->QueryApplication ());
            InterfacePtr<ISubject> iAppSubject (iApp, IID_ISUBJECT);
            if(iAppSubject)
                      iAppSubject->AttachObserver(obsv , IID_IAPPLICATION);
            and in the update of the appObserver I have:
            do {
                                if( theChange.Get ()== kAppBoss)
                                          if(protocol.Get()==IID_IAPPLICATION){
                               if(theChange==kApplicationSuspendMsg){
        fprintf(stderr, "kApplicationSuspendMsg\n");
                                                    if(theChange==kApplicationResumeMsg){
                                                              fprintf(stderr, "kApplicationResumeMsg\n");
            }while(kFalse);
            • 3. Re: How to get notified when InDesign Application hides (Mac)
              rafx79 Level 1
              I have another problem, I think what I need instead is to make my secondary process (with gUI) nest as a child window to indesign's main window, because if I try to use this messages, I'll always receive them when I change focus to the separate window.
              • 4. Re: How to get notified when InDesign Application hides (Mac)
                Manan Joshi Level 4
                As Dirk rightly pointed out, you need to place an observer in the kAppBoss and observe on the IID_IAPPLICATION protocol.
                What you should do is just place an interface as an addin in the kAppBoss and give it an implementation (you don't need to create a observer boss class as you have done).
                In startup call the autoattach of your observer, for ex
                  InterfacePtr<IApplication> app(gSession->QueryApplication());
                  InterfacePtr<IObserver> iMyObserver(app, IID_IMYOBSERVER);
                                    iMyObserver->AutoAttach();
                In the autoattach method of your implementation class, remember to pass your observers interface ID to the attachobsever method of the ISubject
                for ex
                AttachObserver(this, IID_IAPPLICATION, IID_IMYPOBSERVER);
                Then in the update method you will get properly notified of the suspend and resume of application
                This should fix your problem.
                Manan Joshi
                - Efficient InDesign Solutions -
                MetaDesign Solutions
                http://metadesignsolutions.com/services/indesign-development.php
