Hi everyone,
I've got a project on the horizon that involves using an API to access a database. The API uses COM objects.
Can I connect to the API using <cfobject> like this:
<cfobject
class = "program ID"
name = "myneatobject"
action = "connect"
context = "remote"
server = "http://someserverip">
type = "com">
If the server is remote, isn't there some security involved? Login credinentials? I'm trying to ge my head around this. There's an exisiting website in place using the API, however we're planning on redoing everything in CF.
Thanks for any tips in to set me straight!
Yes, cfobject is one possible way to connect to a COM object. The assumption is that ColdFusion already has access to the server hosting the COM object. So it is up to you to ensure ColdFusion has the right security credentials.
Hmm. So, does ColdFusion need to be on the same server as the server hosting the COM object? If not, then can the CFadmin (running the website) be set to connect to the remote server hosting the COM object? Is this configured in the CFadmin "Data&Services>Web Services"??
"ColdFusion lets you register web services so that you do not have to specify the entire Web Services Description Language (WSDL) URL when invoking the web service. ColdFusion automatically registers WSDL URLs the first time they are referenced."
Webservice Name
ESDL URL
Username
Password
With CF 5 and earlier, it was possible to register a remote DCOM service on the machine running CF, and have CF invoke that. I have no idea whether that's possible with newer versions of CF, as the way they interact with COM is quite a bit different.
No. SOAP web services are an entirely different thing. Perhaps whoever created the COM API also created a SOAP API, though.
Dave Watts, CTO, Fig Leaf Software
It is possible.
It is possible.
More info might be useful here. I was with Dave on this one, I thought you'd have to write a CF webservice as a proxy, which connected locally to a COM object and exposed it via a CFC. Luckily it's not 1998 so I rarely have to use COM objects any more.
I'd suggest the OP just gives it a go; there are so many reasons it may or may not work I'm not sure you'll ever get a clear answer.
Owain North wrote:
It is possible.
For more info, see the section Registering Objects in this book chapter about extending ColdFusion with COM. See also this previous ColdFusion forum thread containing example code for a local COM object.
I'm sorry to hear that. I would look to see if there are any alternative approaches that might work better. And practically anything will work better. Is there a Java API? How about .NET? Or, how about accessing the database directly via JDBC? COM objects have never worked well with CF, and they work less well from newer versions of CF than they did with older versions.
<cfobject
action = "connect"
context = "remote"
type = "com">
Almost certainly, no. To connect to COM objects on a remote server, those objects have to support DCOM ("Distributed COM"). In almost all likelihood, these are not DCOM objects. If they were DCOM objects, you wouldn't be able to use an HTTP URL to refer to the server anyway - CF doesn't support that, and many DCOM servers don't support that either.
This would be a matter of how DCOM is configured, and the user account with which CF itself is logged in. By default, CF runs as SYSTEM, which isn't really an account at all and has no network privileges.
<cfobject
action = "connect"
context = "remote"
type = "com">
I would say, almost certainly, yes!
<cfobject
action = "connect"
context = "remote"
type = "com">
I didn't know you could use that syntax for the SERVER attribute, so thanks!
Thanks Guys.
To be sure I'm describing this properly, I've got the manual for the API (updated in 2009) and it states
"The API is a COM+ application (formerly MTS). It
provides a set of COM objects that can be manipulated by COM-
compliant development tools such as Visual Basic, Visual C++, Visual
C#, VSTA and so on.
The API provides the ability to search and locate accounts across
multiple databases. It uses an advanced data cache mechanism to
minimize round-trips to database servers.
Once the account is located using a 10-digit telephone, and
optionally an account number, each subsequent attempt to connect to an
database requires a company number as well as a valid account
number."
The following example shows how to modify an existing user profile information:
Dim objUserProfile as Object
Dim lRetCode as Integer
Set objUserProfile = CreateObject("EnergyAPI.cUserProfile")
lRetCode = objUserProfile.ModifyUserInfo (sEmailAddress,
sPassword,sName,sPAsswordHint,sHintAnswer,lPreferences,cSysUser)
If lRetCode <> 0 Then
‘ Failure - Display error message
Else
‘ Success
End If
COM+ much different than COM?? Not from what I'm reading.
COM+ applications run within a transaction service on a single machine. This is actually good news, as most COM+ applications are designed to be used remotely. If I recall correctly, you'll need to run dcomcnfg.exe on your client to register the DCOM server.
I'd still look for alternatives if they exist, as COM applications don't generally run well under CF.
Well, as I stumble through this I find some additional documentation for the API that states:
"SConnect is a collection of web-services that allow external
applications to programmatically exchange data with the
system. It uses XML documents to move data into and
out of the database(s), this allows SConnect to provide
back office integration to any application capable of creating or
consuming these XML documents.
SConnect offers support for web service com-
munication based on the WS-I basic profile 1.1 (WS-BP 1.1)
specification, this includes standards such SOAP 1.1, WSDL 1.1,
and message security 1.0. It uses HTTP for the transport and of-
fers interoperability across heterogeneous systems."
So, should I be able to SOAP requests?
It just does not look that way. The docs have this example:
Else
‘ Success
End If
In my opinion, that is the wrong example. It falis to show how to "programmatically exchange data with the system.". Yes, you should be able to use SOAP. After all, the documentation says, "SConnect is a collection of web-services...offers support for web service communication based on the WS-I basic profile 1.1 (WS-BP 1.1) specification".
