I have created a Master Project and one Child Project is linked to it. I'm having trouble viewing the index in the child project. I have uploaded it and saved and generated the child project by itself and within the master, and the index isn't appearing. I've created a glossary that works but the index does not. Can someone please help me with this? Thank you!
Image of index in the project manager of the child project:
Go to Project Settings. Are the keywords in the HHK file or in topics? You must have at least one keyword in the HHK file.
If that is not it, create another index with just a couple of index words and generate using that. Any change?
I suspect your merge is not set up correctly. Have you seen the pages on merging on my site? If not take a look there and download the ready made set up. Compare that with your set up.
Post back if still not resolved.
Thanks. I double checked the Merge and it matches. I have 2 other master projects and the indexes are visible there. This index isn't appearing in the child project when i save and generate it nor the master that it is merged with it.
I fixed it! I linked the keywords to the topics before I changed the name of the topics so it wasn't matching up. Thank you so much!
