I am getting this error when I am stop and restart a stream after only a few minutes. These are for new files that are definitely not 2 days old. Any idea why im getting this error?
total 39M drwxrwxrwx 2 fms fms 125 Feb 7 13:41 . drwxrwxrwx 4 fms fms 38 Feb 7 10:30 .. -rw-rw-rw- 1 fms fms 2.5K Feb 7 13:41 live160-2.bootstrap -rw-rw-rw- 1 fms fms 16 Feb 7 10:44 live160-2.control -rw-rw-rw- 1 fms fms 434 Feb 7 10:41 live160-2.meta -rw-rw-rw- 1 fms fms 39M Feb 7 10:44 live160-2Seg1.f4f -rw-rw-rw- 1 fms fms 6.5K Feb 7 13:41 live160-2Seg1.f4x
2012-02-07 13:20:15 9058 (w)2611179 Warning from libf4f.so: [Utils] [live160-2] Discarded all queued Media Messages received before first Video Keyframe Message . - 2012-02-07 13:20:15 9058 (e)2611178 Error from libf4f.so: [Utils] [live160-2] [live160-2] Restarting the recording after 2.000000 days is not allowed. Stopping the recording. Please change the config parameter <MaxRestartGap> under <Recording> in event.xml if you would like to increase this . - 2012-02-07 13:20:15 9058 (e)2611178 Error from libf4f.so: f4fAdaptor::record failed. Error: Failed to push media message. - 2012-02-07 13:20:15 9058 (e)2611082 Failed to record live160-2. - 2012-02-07 13:20:15 9058 (e)2611178 Error from libf4f.so: f4fAdaptor::record failed. Error: Failed to push media message. -
What encoder are you using for publishing. Please try with making changes in encoder settings to send the absolute timestamps.. For example in FMLE, you can change syncronisation=true in config.ini..
Because, I suspect that your encoder might be sending from 0 timestamp again as you restart the publishing..
As the error mentioned, you should also (along with enabling ATC) change the maxrestartgap in event.xml to support more than 2 days of un-restarted recording.
What to set in MaxRestartGap?
There is no need to set anything explicit for you issue for this tag. You just need to change what Nitin suggested. If you are done with that then it should take care of your issue. Its only when you have content which is 2 days old and then you decide to append that data after restarting recording after 2 days - then you need to change this tag value - otherwise it can remain the same.
Thank you for fast response. I've set time sync to true, but same error occured after two days.
Now I've set restart interval to 0 days and 47 hours Still not clear how (what) to set for MaxRestartGap tag.
So now, you must not be getting the recording issue in case you restart the stream within 2 days..right?
In case, you want stream to be recorded in append mode even after republishing after two days.. You may change in your event.xml by adding or modifying the tag
<MaxRestartGap>3</MaxRestartGap>
unders <Recording> section.
Keeping value 3, will allow you to restart stream max within 3 days of the gap.
However, in case you your requirement is not to append to the previous data.. just a fresh recording everytime.. you may choose to modify the livepkgr main.asc to change the recordMode from "append" to "" (empty string)
So unit of MaxRestartGap is days..
Nitin
You mentioned changing append to and empty string but I did not think it was possible to alter this in the FMS 4.5.1 streaming edition. I am in the position where I do want just want a fresh recording everytime there is a disconnect ( actually I don't want any recording but I understand that some is required for HTTP Live streams).
Currently we have to monitor the streams directory for Bootstrap files that are older than a minute or two and then clear down the contents of the directory to force a new recording. It is essential that we find a better way of dealing with live stream interruptions as they will happen like it or not.
Nitin Wrote;
>However, in case you your requirement is not to append to the previous data.. just a fresh recording everytime.. you may choose to modify the livepkgr main.asc to change the >recordMode from "append" to "" (empty string)
I look forward to hearing from you.
Peter
Nitin said: "...you may choose to modify the livepkgr main.asc to change the >recordMode from "append" to "" (empty string).."
I have changed mine to "record" - is it wrong?
No its not wrong - but what Nitin suggested in another post of his of using query paramter is more flexible way of doing it. Remember any change in code requires App Reload - which you can avoid using query parameter way.
Remember that in the Streaming Edition I don't think you can change the Main.asc file so the query parameter is the only way to do this.
Peter
Ok, i get it, i was only asking if i change to "record" inside server side code in livepkgr - will it work correctly in record mode or not. (after app reload)
I am still getting the error. Setting the absolute timestamp didn't help.
I am using Adobe FMLE and Wirecast on various platforms and im having the same trouble on both. I've set the logging level on a test server to Verbose and I was able to get a little more info.
In this test, I started a stream at 1:31PM, stopped it, and restarted it 5 minutes later, and it worked. Then I restarted it 20 minutes after and got the MaxRestartGap error.
Feb 24 13:31:17 adbefms Stream[11610]: Info from libf4f.so: [Utils] [atc_test1] Received ATC offset: 0 . Feb 24 13:31:24 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] processed onMetadata message. Skipping message . Feb 24 13:31:24 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] Pushed another sample . Feb 24 13:31:24 adbefms last message repeated 468 times Feb 24 13:31:24 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] Completed Fragment #1 . Feb 24 13:31:30 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] Pushed another sample . Feb 24 13:31:30 adbefms last message repeated 439 times Feb 24 13:31:30 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] Completed Fragment #2 . Feb 24 13:31:35 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] Pushed another sample . Feb 24 13:31:35 adbefms last message repeated 357 times Feb 24 13:31:35 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] completeFragment(): Gap in fragment numbers: Expected 3. Got 4. Assuming the rest of the fragments are skipped . Feb 24 13:31:35 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] Completed Fragment #4 . Feb 24 13:31:35 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] End of stream . Feb 24 13:34:35 adbefms Stream[11610]: Info from libf4f.so: [Utils] [atc_test1] Received ATC offset: 179951 . Feb 24 13:34:48 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] Pushed another sample . Feb 24 13:34:48 adbefms last message repeated 441 times Feb 24 13:34:48 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] completeFragment(): Gap in fragment numbers: Expected 5. Got 52. Assuming the rest of the fragments are skipped . Feb 24 13:34:48 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] Completed Fragment #52 . Feb 24 13:34:49 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] Pushed another sample . Feb 24 13:34:49 adbefms last message repeated 144 times Feb 24 13:34:49 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] Completed Fragment #53 . Feb 24 13:34:49 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] End of stream . Feb 24 13:52:47 adbefms Stream[11610]: Info from libf4f.so: [Utils] [atc_test1] Received ATC offset: 4294754452 . Feb 24 13:52:48 adbefms Stream[11610]: Error from libf4f.so: [Utils] [atc_test1] [atc_test1] Restarting the recording after 2.000000 days is not allowed. Stopping the recording. Please change the config parameter under in event.xml if you would like to increase this . Feb 24 13:52:48 adbefms Stream[11610]: Error from libf4f.so: f4fAdaptor::record failed. Error: Failed to push media message. Feb 24 13:52:48 adbefms Stream[11610]: Failed to record atc_test1. Feb 24 13:52:48 adbefms Stream[11610]: Error from libf4f.so: f4fAdaptor::record failed. Error: Failed to push media message. Feb 24 13:52:48 adbefms Stream[11610]: Info from libf4f.so: [Fragmenter] [atc_test1] End of stream .
This is the contents of the log in the admin console:
onPublish : atc_test1 Stream name is: atc_test1 and live event is: timecodetest f4f:atc_test1 - NetStream.Data.Start f4f:atc_test1 - NetStream.Play.Reset f4f:atc_test1 - NetStream.Publish.Start f4f:atc_test1 - NetStream.Record.Start f4f:atc_test1 - NetStream.Play.UnpublishNotify onUnpublish : atc_test1 f4f:atc_test1 - NetStream.Record.Stop f4f:atc_test1 - NetStream.Play.Stop f4f:atc_test1 - NetStream.Unpublish.Success onPublish : atc_test1 Stream name is: atc_test1 and live event is: timecodetest f4f:atc_test1 - NetStream.Data.Start f4f:atc_test1 - NetStream.Publish.Start f4f:atc_test1 - NetStream.Play.Reset f4f:atc_test1 - NetStream.Record.Start onUnpublish : atc_test1 f4f:atc_test1 - NetStream.Play.UnpublishNotify f4f:atc_test1 - NetStream.Record.Stop f4f:atc_test1 - NetStream.Unpublish.Success onPublish : atc_test1 Stream name is: atc_test1 and live event is: timecodetest f4f:atc_test1 - NetStream.Data.Start f4f:atc_test1 - NetStream.Play.Reset f4f:atc_test1 - NetStream.Publish.Start f4f:atc_test1 - NetStream.Record.Start f4f:atc_test1 - NetStream.Record.NoAccess f4f:atc_test1 - NetStream.Record.Stop f4f:atc_test1 - NetStream.Record.NoAccess f4f:atc_test1 - NetStream.Play.UnpublishNotify onUnpublish : atc_test1 f4f:atc_test1 - NetStream.Play.Stop f4f:atc_test1 - NetStream.Unpublish.Success
This is still happening. Anybody else run into this?
Please share your
1. Application.xml settings in the livepkgr app
2. config.ini in the FMLE.
I will try to repro at my end..
<Application> <StreamManager> <Live> <!-- When enabled, the server will assume that incoming live streams have --> <!-- timestamps that are based on an absolute clock, such as a SMPTE time --> <!-- signal contained within the encoder's input source. --> <!-- Default is false. --> <AssumeAbsoluteTime>true</AssumeAbsoluteTime> <!-- Allow take over so that encoders that go down (for some reason) and --> <!-- and come back up can immediately republish. --> <PublishTimeout>0</PublishTimeout> </Live> </StreamManager> </Application>
########################################################################### # fms.ini contains substitution variables for Flash Media Server # # configuration files. Lines beginning with '#' are considered comments. # # A substitution variable is in the form =. Everything up to # # the first '=' is considered the name of the substitution variable, and # # everything after the first '=' is considered the substitution value. If # # you want a substitution variable to have leading or trailing spaces, # # enclose the value around double quotes. For example, foo=" bar " # ########################################################################### ############################################################### # This section contains configurable parameters in Server.xml # ############################################################### # Username for server admin # For example: # SERVER.ADMIN_USERNAME = foo # SERVER.ADMIN_USERNAME = allan # IP address and port Flash Media Admin Server should listen on # For example: # SERVER.ADMINSERVER_HOSTPORT = :1111 # SERVER.ADMINSERVER_HOSTPORT = :1111 # User id in which to run the process (Linux Only) # For example: # SERVER.PROCESS_UID = 500 # SERVER.PROCESS_UID = 500 # Group id in which to run the process (Linux Only) # For example: # SERVER.PROCESS_GID = 500 # SERVER.PROCESS_GID = 500 # License key for Flash Media Server # For example: # SERVER.LICENSEINFO = XXXX-XXXX-XXXX-XXXX-XXXX-XXXX # SERVER.LICENSEINFO = # LIVE_DIR denotes the full path of sample "Live" application's # folder for storing any live stream recorded by server. # For example: # LIVE_DIR = \applications\live # ####LIVE_DIR = /opt/adobe/fms/applications/live LIVE_DIR = /mnt/media/live_recordings/live # VOD_COMMON_DIR denotes the full path of sample "VOD" application's # folder for storing onDemand and Progressive Download .flv/.mp3 files. # File stored in this folder can be streamed and are also PD-able. # Note : If you are using the default installation of Apache as a webserver, # and if you modify VOD_COMMON_DIR, please change the document root # accordingly in httpd.conf. # For example: # VOD_COMMON_DIR = \webroot\vod # VOD_COMMON_DIR = /opt/adobe/fms/webroot/vod # VOD_DIR denotes the full path of sample "VOD" application's # folder for storing onDemand only .flv/.mp3 files. Files stored in # this folder are not PD-able # For example: # VOD_DIR = \applications\vod\media # ####VOD_DIR = /opt/adobe/fms/applications/vod/media VOD_DIR = /mnt/media/live_recordings/vod/media # The maximum size of the FLV cache, in megabytes. # The default is 500MB. # SERVER.FLVCACHE_MAXSIZE=500 # Whether to start and stop the included HTTP server along # with FMS. # SERVER.HTTPD_ENABLED = true ################################################################ # This section contains configurable parameters in Adaptor.xml # ################################################################ # IP address and port(s) Flash Media Server should listen on # For example: # ADAPTOR.HOSTPORT = :1935,80 # ADAPTOR.HOSTPORT = :1935 # IP (address and) port that Flash Media Server should proxy # unknown HTTP requests to. Leave empty to disable proxying. # With no address, specifies a localhost port. # For example: # HTTPPROXY.HOST = webfarm.example.com:80 HTTPPROXY.HOST = :8134 #This tag specifies an IP address for the player to use instead of a hostname when #making the RTMPT connection to FMS. If nothing is specified, FMS will automatically #determine the IP to use. # ADAPTOR.HTTPIDENT2 = ############################################################## # This section contains configurable parameters in Vhost.xml # ############################################################## # Application directory for the virtual host # For example: # VHOST.APPSDIR = C:\myapps # ####VHOST.APPSDIR = /opt/adobe/fms/applications VHOST.APPSDIR = /mnt/media/live_recordings #################################################################### # This section contains configurable parameters in Application.xml # #################################################################### # List of semi-colon delimited paths in which to search for script to load # For example: # APP.JS_SCRIPTLIBPATH = C:\scripts;C:\Program Files\Foo\scripts # APP.JS_SCRIPTLIBPATH = /opt/adobe/fms/scriptlib ############################################################### # This section contains configurable parameters in Logger.xml # ############################################################### LOGGER.LOGDIR = #################################################################### # This section contains configurable parameters in Users.xml # #################################################################### # Enable or disable using HTTP requests to execute admin commands. # Set to "true" to enable, otherwise it will be disabled. The # actual commands permitted for server admin and virtual host admin # users can be set in Users.xml. USERS.HTTPCOMMAND_ALLOW = true
Nitin has asked for config.xml of FMLE and not fms.ini of FMS. You can find config.xml (i think by mistake Nitin put wrong extenstion) for FMLE - you can find the same in <installDir of FMLE>/Conf
<?xml version="1.0" encoding="UTF-16"?> <flashmedialiveencoder_config> <!-- This tag configures FMLE for the case when audio device sends audio samples--> <!-- with forward timestamp. In this case FMLE can be configured to send --> <!-- silence audio message between samples that have forward timestamp. --> <filler> <!-- Min Forward timestamp duration (in Milli Seconds). --> <!-- Default value is 50ms. --> <duration>50</duration> <!-- Buffersize for the resampler and filler --> <!-- Default value is 2000ms. --> <buffersize>2000</buffersize> </filler> <!-- This tag configures FMLE for Debug Log writings. --> <!-- Debug logs for audio, video, rtmp, etc. are created and can be analyzed --> <!-- for troubleshooting purposes. --> <!-- Logs are created in folder "stats_yyyymmdd_hhmmss" inside MyVideos --> <!-- directory by default. Logs directory path can be changed using "path" --> <!-- tag. --> <logs> <!-- Enable/Disable log writings. --> <!-- "true" to Enable log writings. --> <!-- "false" to Disable. --> <enable>false</enable> <!-- Logs Directory path. --> <!-- For Example, "C:\FMLE Logs". --> <!-- By Default MyVideos is taken. --> <path></path> </logs> <mbrconfig> <!-- Multiple Stream synchronization at FMS. --> <!-- This feature can be used to synchronize streams from multiple FMLE --> <!-- instances running on multiple machines. --> <!-- All the streams are synchronized using a common reference UTC --> <!-- (Coordinated Universal Time) time. --> <!-- All the FMLE stream that needs to be synchronized should be configured --> <!-- with same reference time and the machine on which FMLE instances are --> <!-- running should be synchronized using NTP (Network Time Protocol) --> <!-- for proper stream synchronization at FMS. --> <!-- This feature is disabled by default. --> <streamsynchronization> <!-- "true" to enable this feature, "false" to disable. --> <enable>true</enable> <!-- A Past UTC reference time. --> <!-- Past reference time should not be earlier than 30 days from the --> <!-- time when encoding is started. --> <!-- If invalid reference time is provided, current month is taken as --> <!-- reference time. --> <referencetime> <!-- A past/current month. --> <!-- 1 for January, 2 for February and so on. --> <!-- 0 means use current month. --> <month>0</month> <!-- A past/current year. --> <!-- for Example, 2008,2009 etc. --> <!-- 0 means use current year. --> <year>0</year> </referencetime> </streamsynchronization> </mbrconfig> <rtmpconfig> <!-- Maximum RTMP buffer size and buffer duration configuration. --> <!-- This tag can be used to set maximum RTMP buffer size and maximum --> <!-- buffer duration at FMLE side. --> <!-- Sometimes while publishing in adverse network condition (low bandwidth,--> <!-- high latency, etc.), the RTMP buffer at FMLE could grow enormously --> <!-- and cause increase in memory usage (Virtual memory). --> <!-- Very high memory usage can cause application to become unresponsive --> <!-- or even crash. --> <!-- Use this tag to set a threshold value for the RTMP buffer. Once any --> <!-- of the threshold value (maxrtmpbuffersize or maxrtmpbufferlength) is --> <!-- reached, FMLE flushes the RTMP buffer and re-publishes the streams. --> <!-- When the RTMP buffer is flushed, all the data in the buffer is --> <!-- discarded, leading to loss of the bufferd data. --> <!-- In order to avoid increase in RTMP buffer and prevent the data loss, --> <!-- use AutoAdjust feature. Please refer to help file for AutoAdjust. --> <!-- This feature is enabled by default. --> <rtmpbuffercontrol> <!-- "true" to enable this feature, "false" to disable." --> <enable>true</enable> <!-- Maximum RTMP buffer size. (in KB) --> <!-- This tag specifies how large the RTMP buffer size could grow. --> <!-- default value is 512MB (512,000KB). --> <maxrtmpbuffersize>512000</maxrtmpbuffersize> <!-- Maximum RTMP buffer Length/duration (in Seconds). --> <!-- This tag specifies the maximum RTMP buffer length/duration. --> <!-- Use this tag to set the threshold value for the RTMP buffer length.--> <!-- Default value is 3600 seconds ( 1 hour). --> <maxrtmpbufferlength>3600</maxrtmpbufferlength> </rtmpbuffercontrol> </rtmpconfig> </flashmedialiveencoder_config>
Try changing livestream and liveevent name.
I have same issue if i use same name, but if i change the name everything goes fine.
Like there is 'overwrite forbiden'.
Now second part is how to set it up to work with sam stream name.
BR
Vlado
I have not had any problems using the same names for livestream and
livevent as far as I am aware we have several streams running in
separate livepkgr instances with the same stream and event name.
I will investigate further.
Peter
I am sorry.. Couldn't get time to investigate this on my side.. Will check if someone in my team can take this up.. Will keep this in my list..
Also, you have valid concerns that we can't change recording mode in streaming edition. All I can say that streaming edition comes with minimal power right now.. But I got your concern and will forward it to my team - how we can improve streaming edition's user experience with livepkgr application.
Thanks for giving us thoughts on improving the FMS.
Hey, you can do one thing.. in case you want to record in "record" mode rather than "append"
add query parameter adbe-record-mode="record" in the publish stream.
for example publish
livestream?adbe-live-event="liveevent"&adbe-record-mode="record"
Is there any documentation on this parametars?
It works now when i add it to my stream, but i dont know what it does.
Will it record whole stream to file, or?
Also,
I have FMS 4.5 Streaming edition installed, but i dont want to record streams.
Where can i chenge this?
BR
Vlado
In Event.xml in the recording section you can use this in the <Recording> section the number used refers to hours of recordings on disk.
<DiskManagementDuration>0.1</DiskManagementDuration>
We are not interested in recording so keep it fairly small. I guess if you are utilising the DVR function this will have to big enough to fulfill the DVR needs.
There are other sections in the Application.xml where you can set recording time but they did not seem to have much impact in the streaming edition.
Hope that help
Peter
